I have been trying to compile Luxcore with LinuxCompile, both of release 2.0. The issue is that it fails during the Qt compilation.
Here is the console output:
gcc -c -w -mtune=generic -std=gnu++98 -mmmx -msse -msse2 -O2 -pipe -mfpmath=sse -fPIC -I/home/ernesto/luxcorerender/LinuxCompile-luxcorerender_v2.0/target-64-sse2/include/libpng -fno-exceptions -O2 -fvisibility=hidden -Wall -W -D_REENTRANT -fPIC -DQT_BUILD_CORE_LIB -DQT_NO_USING_NAMESPACE -DQT_NO_CAST_TO_ASCII -DQT_ASCII_CAST_WARNINGS -DQT_MOC_COMPAT -DQT_USE_QSTRINGBUILDER -DQLIBRARYINFO_EPOCROOT -DQT_USE_ICU -DHB_EXPORT=Q_CORE_EXPORT -DQT_NO_DEBUG -DQT_HAVE_MMX -DQT_HAVE_SSE -DQT_HAVE_MMXEXT -D_LARGEFILE64_SOURCE -D_LARGEFILE_SOURCE -I../../mkspecs/linux-g++ -I. -I../../include -I../../include/QtCore -I.rcc/release-static -Iglobal -I../../tools/shared -I../3rdparty/zlib -I../3rdparty/harfbuzz/src -I../3rdparty/md5 -I../3rdparty/md4 -I.moc/release-static -o .obj/release-static/harfbuzz-open.o ../3rdparty/harfbuzz/src/harfbuzz-open.c
In file included from /usr/include/unicode/uversion.h:30:0,
from tools/qlocale_icu.cpp:46:
/usr/include/unicode/umachine.h:347:13: error: ‘char16_t’ does not name a type; did you mean ‘wchar_t’?
typedef char16_t UChar;
wchar_t
In file included from tools/qlocale_icu.cpp:46:0:
/usr/include/unicode/uversion.h:167:55: error: ‘UChar’ does not name a type; did you mean ‘QChar’?
u_versionFromUString(UVersionInfo versionArray, const UChar *versionString);
QChar
In file included from /usr/include/unicode/unorm.h:24:0,
from /usr/include/unicode/ucol.h:17,
from tools/qlocale_icu.cpp:47:
/usr/include/unicode/uiter.h:594:44: error: ‘UChar’ does not name a type; did you mean ‘QChar’?
uiter_setString(UCharIterator *iter, const UChar *s, int32_t length);
QChar
In file included from /usr/include/unicode/uset.h:33:0,
from /usr/include/unicode/unorm2.h:36,
from /usr/include/unicode/unorm.h:25,
/usr/include/unicode/uchar.h:3724:33: error: ‘UChar’ has not been declared
u_getFC_NFKC_Closure(UChar32 c, UChar *dest, int32_t destCapacity, UErrorCode *pErrorCode);
In file included from /usr/include/unicode/unorm2.h:36:0,
/usr/include/unicode/uset.h:285:24: error: ‘UChar’ does not name a type; did you mean ‘QChar’?
uset_openPattern(const UChar* pattern, int32_t patternLength,
QChar
/usr/include/unicode/uset.h:300:31: error: ‘UChar’ does not name a type; did you mean ‘QChar’?
uset_openPatternOptions(const UChar* pattern, int32_t patternLength,
QChar
/usr/include/unicode/uset.h:422:25: error: ‘UChar’ does not name a type; did you mean ‘QChar’?
const UChar *pattern, int32_t patternLength,
QChar
/usr/include/unicode/uset.h:489:31: error: ‘UChar’ does not name a type; did you mean ‘QChar’?
const UChar *prop, int32_t propLength,
QChar
/usr/include/unicode/uset.h:490:31: error: ‘UChar’ does not name a type; did you mean ‘QChar’?
const UChar *value, int32_t valueLength,
QChar
/usr/include/unicode/uset.h:503:29: error: ‘UChar’ does not name a type; did you mean ‘QChar’?
uset_resemblesPattern(const UChar *pattern, int32_t patternLength,
QChar
/usr/include/unicode/uset.h:523:16: error: ‘UChar’ has not been declared
UChar* result, int32_t resultCapacity,
/usr/include/unicode/uset.h:575:33: error: ‘UChar’ does not name a type; did you mean ‘QChar’?
uset_addString(USet* set, const UChar* str, int32_t strLen);
QChar
/usr/include/unicode/uset.h:587:40: error: ‘UChar’ does not name a type; did you mean ‘QChar’?
uset_addAllCodePoints(USet* set, const UChar *str, int32_t strLen);
QChar
/usr/include/unicode/uset.h:622:36: error: ‘UChar’ does not name a type; did you mean ‘QChar’?
uset_removeString(USet* set, const UChar* str, int32_t strLen);
QChar
/usr/include/unicode/uset.h:796:44: error: ‘UChar’ does not name a type; did you mean ‘QChar’?
uset_containsString(const USet* set, const UChar* str, int32_t strLen);
QChar
/usr/include/unicode/uset.h:867:14: error: ‘UChar’ has not been declared
UChar* str, int32_t strCapacity,
/usr/include/unicode/uset.h:892:51: error: ‘UChar’ does not name a type; did you mean ‘QChar’?
uset_containsAllCodePoints(const USet* set, const UChar *str, int32_t strLen);
QChar
/usr/include/unicode/uset.h:936:34: error: ‘UChar’ does not name a type; did you mean ‘QChar’?
uset_span(const USet *set, const UChar *s, int32_t length, USetSpanCondition spanCondition);
QChar
/usr/include/unicode/uset.h:957:38: error: ‘UChar’ does not name a type; did you mean ‘QChar’?
uset_spanBack(const USet *set, const UChar *s, int32_t length, USetSpanCondition spanCondition);
QChar
In file included from /usr/include/unicode/unorm.h:25:0,
/usr/include/unicode/unorm2.h:285:24: error: ‘UChar’ does not name a type; did you mean ‘QChar’?
const UChar *src, int32_t length,
QChar
/usr/include/unicode/unorm2.h:286:18: error: ‘UChar’ has not been declared
UChar *dest, int32_t capacity,
/usr/include/unicode/unorm2.h:308:33: error: ‘UChar’ has not been declared
UChar *first, int32_t firstLength, int32_t firstCapacity,
/usr/include/unicode/unorm2.h:309:39: error: ‘UChar’ does not name a type; did you mean ‘QChar’?
const UChar *second, int32_t secondLength,
QChar
/usr/include/unicode/unorm2.h:331:15: error: ‘UChar’ has not been declared
/usr/include/unicode/unorm2.h:332:21: error: ‘UChar’ does not name a type; did you mean ‘QChar’?
QChar
/usr/include/unicode/unorm2.h:356:36: error: ‘UChar’ has not been declared
UChar32 c, UChar *decomposition, int32_t capacity,
/usr/include/unicode/unorm2.h:390:39: error: ‘UChar’ has not been declared
/usr/include/unicode/unorm2.h:441:27: error: ‘UChar’ does not name a type; did you mean ‘QChar’?
QChar
/usr/include/unicode/unorm2.h:463:25: error: ‘UChar’ does not name a type; did you mean ‘QChar’?
QChar
/usr/include/unicode/unorm2.h:492:32: error: ‘UChar’ does not name a type; did you mean ‘QChar’?
QChar
/usr/include/unicode/unorm2.h:597:21: error: ‘UChar’ does not name a type; did you mean ‘QChar’?
unorm_compare(const UChar *s1, int32_t length1,
QChar
/usr/include/unicode/unorm2.h:598:21: error: ‘UChar’ does not name a type; did you mean ‘QChar’?
const UChar *s2, int32_t length2,
QChar
In file included from /usr/include/unicode/ucol.h:17:0,
/usr/include/unicode/unorm.h:214:23: error: ‘UChar’ does not name a type; did you mean ‘QChar’?
unorm_normalize(const UChar *source, int32_t sourceLength,
QChar
/usr/include/unicode/unorm.h:216:17: error: ‘UChar’ has not been declared
UChar *result, int32_t resultLength,
/usr/include/unicode/unorm.h:240:24: error: ‘UChar’ does not name a type; did you mean ‘QChar’?
unorm_quickCheck(const UChar *source, int32_t sourcelength,
QChar
/usr/include/unicode/unorm.h:261:35: error: ‘UChar’ does not name a type; did you mean ‘QChar’?
unorm_quickCheckWithOptions(const UChar *src, int32_t srcLength,
QChar
/usr/include/unicode/unorm.h:287:26: error: ‘UChar’ does not name a type; did you mean ‘QChar’?
unorm_isNormalized(const UChar *src, int32_t srcLength,
QChar
/usr/include/unicode/unorm.h:309:37: error: ‘UChar’ does not name a type; did you mean ‘QChar’?
unorm_isNormalizedWithOptions(const UChar *src, int32_t srcLength,
QChar
/usr/include/unicode/unorm.h:388:12: error: ‘UChar’ has not been declared
/usr/include/unicode/unorm.h:421:16: error: ‘UChar’ has not been declared
/usr/include/unicode/unorm.h:464:25: error: ‘UChar’ does not name a type; did you mean ‘QChar’?
unorm_concatenate(const UChar *left, int32_t leftLength,
QChar
/usr/include/unicode/unorm.h:465:25: error: ‘UChar’ does not name a type; did you mean ‘QChar’?
const UChar *right, int32_t rightLength,
QChar
/usr/include/unicode/unorm.h:466:19: error: ‘UChar’ has not been declared
In file included from /usr/include/unicode/ucol.h:19:0,
/usr/include/unicode/parseerr.h:83:5: error: ‘UChar’ does not name a type; did you mean ‘QChar’?
UChar preContext[U_PARSE_CONTEXT_LEN];
QChar
/usr/include/unicode/parseerr.h:90:5: error: ‘UChar’ does not name a type; did you mean ‘QChar’?
UChar postContext[U_PARSE_CONTEXT_LEN];
QChar
In file included from /usr/include/unicode/uloc.h:27:0,
from /usr/include/unicode/ucol.h:20,
/usr/include/unicode/uenum.h:112:16: error: ‘UChar’ does not name a type; did you mean ‘QChar’?
U_STABLE const UChar* U_EXPORT2
QChar
/usr/include/unicode/uenum.h:190:41: error: ‘UChar’ does not name a type; did you mean ‘QChar’?
uenum_openUCharStringsEnumeration(const UChar* const strings[], int32_t count,
QChar
In file included from /usr/include/unicode/ucol.h:20:0,
/usr/include/unicode/uloc.h:571:13: error: ‘UChar’ has not been declared
UChar* language,
/usr/include/unicode/uloc.h:594:13: error: ‘UChar’ has not been declared
UChar* script,
/usr/include/unicode/uloc.h:619:24: error: ‘UChar’ has not been declared
UChar* country,
/usr/include/unicode/uloc.h:643:24: error: ‘UChar’ has not been declared
UChar* variant,
/usr/include/unicode/uloc.h:690:24: error: ‘UChar’ has not been declared
UChar* dest,
/usr/include/unicode/uloc.h:717:32: error: ‘UChar’ has not been declared
UChar* dest,
/usr/include/unicode/uloc.h:739:13: error: ‘UChar’ has not been declared
UChar* result,
In file included from /usr/include/unicode/ucol.h:22:0,
/usr/include/unicode/uscript.h:607:45: error: ‘UChar’ has not been declared
uscript_getSampleString(UScriptCode script, UChar *dest, int32_t capacity, UErrorCode *pErrorCode);
In file included from tools/qlocale_icu.cpp:47:0:
/usr/include/unicode/ucol.h:428:23: error: ‘UChar’ does not name a type; did you mean ‘QChar’?
ucol_openRules( const UChar *rules,
QChar
/usr/include/unicode/ucol.h:561:18: error: ‘UChar’ does not name a type; did you mean ‘QChar’?
QChar
/usr/include/unicode/ucol.h:563:18: error: ‘UChar’ does not name a type; did you mean ‘QChar’?
const UChar *target,
QChar
/usr/include/unicode/ucol.h:609:20: error: ‘UChar’ does not name a type; did you mean ‘QChar’?
QChar
/usr/include/unicode/ucol.h:610:20: error: ‘UChar’ does not name a type; did you mean ‘QChar’?
const UChar *target, int32_t targetLength);
QChar
/usr/include/unicode/ucol.h:628:27: error: ‘UChar’ does not name a type; did you mean ‘QChar’?
QChar
/usr/include/unicode/ucol.h:629:27: error: ‘UChar’ does not name a type; did you mean ‘QChar’?
QChar
/usr/include/unicode/ucol.h:647:18: error: ‘UChar’ does not name a type; did you mean ‘QChar’?
QChar
/usr/include/unicode/ucol.h:648:18: error: ‘UChar’ does not name a type; did you mean ‘QChar’?
QChar
/usr/include/unicode/ucol.h:800:13: error: ‘UChar’ has not been declared
UChar *result,
/usr/include/unicode/ucol.h:932:16: error: ‘UChar’ does not name a type; did you mean ‘QChar’?
QChar
/usr/include/unicode/ucol.h:1017:18: error: ‘UChar’ does not name a type; did you mean ‘QChar’?
QChar
/usr/include/unicode/ucol.h:1272:27: error: ‘UChar’ does not name a type; did you mean ‘QChar’?
const UChar *varTop, int32_t len,
QChar
/usr/include/unicode/ucol.h:1361:62: error: ‘UChar’ has not been declared
ucol_getRulesEx(const UCollator *coll, UColRuleOption delta, UChar *buffer, int32_t bufferLen);
tools/qlocale_icu.cpp:53:75: error: ‘UChar’ does not name a type; did you mean ‘QChar’?
typedef UCollationResult (*Ptr_ucol_strcoll)(const UCollator *coll, const UChar *source, int32_t sourceLength, const UChar *target, int32_t targetLength);
QChar
tools/qlocale_icu.cpp:53:118: error: ‘UChar’ does not name a type; did you mean ‘QChar’?
QChar
tools/qlocale_icu.cpp:54:36: error: typedef ‘Ptr_u_strToCase’ is initialized (use decltype instead)
typedef int32_t (*Ptr_u_strToCase)(UChar *dest, int32_t destCapacity, const UChar *src, int32_t srcLength, const char *locale, UErrorCode *pErrorCode);
tools/qlocale_icu.cpp:54:36: error: ‘UChar’ was not declared in this scope
tools/qlocale_icu.cpp:54:36: note: suggested alternative: ‘QChar’
QChar
tools/qlocale_icu.cpp:54:43: error: ‘dest’ was not declared in this scope
tools/qlocale_icu.cpp:54:43: note: suggested alternative: ‘reset’
reset
tools/qlocale_icu.cpp:54:57: error: expected primary-expression before ‘destCapacity’
tools/qlocale_icu.cpp:54:71: error: expected primary-expression before ‘const’
tools/qlocale_icu.cpp:54:97: error: expected primary-expression before ‘srcLength’
tools/qlocale_icu.cpp:54:108: error: expected primary-expression before ‘const’
tools/qlocale_icu.cpp:54:139: error: expected primary-expression before ‘*’ token
tools/qlocale_icu.cpp:54:140: error: ‘pErrorCode’ was not declared in this scope
tools/qlocale_icu.cpp:54:140: note: suggested alternative: ‘UErrorCode’
UErrorCode
tools/qlocale_icu.cpp:59:8: error: ‘Ptr_u_strToCase’ does not name a type; did you mean ‘u_strFoldCase’?
static Ptr_u_strToCase ptr_u_strToUpper = 0;
u_strFoldCase
tools/qlocale_icu.cpp:60:8: error: ‘Ptr_u_strToCase’ does not name a type; did you mean ‘u_strFoldCase’?
static Ptr_u_strToCase ptr_u_strToLower = 0;
u_strFoldCase
tools/qlocale_icu.cpp: In function ‘bool qt_initIcu(const QString&)’:
tools/qlocale_icu.cpp:122:9: error: ‘ptr_u_strToUpper’ was not declared in this scope
ptr_u_strToUpper = (Ptr_u_strToCase)ucLib.resolve("u_strToUpper");
tools/qlocale_icu.cpp:122:9: note: suggested alternative: ‘u_strToUpper’
u_strToUpper
tools/qlocale_icu.cpp:122:29: error: ‘Ptr_u_strToCase’ was not declared in this scope
tools/qlocale_icu.cpp:122:29: note: suggested alternative: ‘u_strFoldCase’
u_strFoldCase
tools/qlocale_icu.cpp:123:9: error: ‘ptr_u_strToLower’ was not declared in this scope
ptr_u_strToLower = (Ptr_u_strToCase)ucLib.resolve("u_strToLower");
tools/qlocale_icu.cpp:123:9: note: suggested alternative: ‘u_strToLower’
u_strToLower
tools/qlocale_icu.cpp: In function ‘bool qt_ucol_strcoll(const QChar*, int, const QChar*, int, int*)’:
tools/qlocale_icu.cpp:168:68: error: ISO C++ forbids declaration of ‘type name’ with no type [-fpermissive]
*result = ptr_ucol_strcoll(icuCollator, reinterpret_cast<const UChar *>(source), int32_t(sourceLength),
tools/qlocale_icu.cpp:168:68: error: expected ‘>’ before ‘UChar’
tools/qlocale_icu.cpp:168:68: error: expected ‘(’ before ‘UChar’
tools/qlocale_icu.cpp:168:68: error: ‘UChar’ was not declared in this scope
tools/qlocale_icu.cpp:168:68: note: suggested alternative: ‘QChar’
QChar
tools/qlocale_icu.cpp:168:75: error: expected primary-expression before ‘>’ token
tools/qlocale_icu.cpp:169:55: error: ISO C++ forbids declaration of ‘type name’ with no type [-fpermissive]
reinterpret_cast<const UChar *>(target), int32_t(targetLength));
tools/qlocale_icu.cpp:169:55: error: expected ‘>’ before ‘UChar’
tools/qlocale_icu.cpp:169:55: error: expected ‘(’ before ‘UChar’
tools/qlocale_icu.cpp:169:62: error: expected primary-expression before ‘>’ token
tools/qlocale_icu.cpp:169:95: error: expected ‘)’ before ‘;’ token
tools/qlocale_icu.cpp: At global scope:
tools/qlocale_icu.cpp:175:85: error: ‘Ptr_u_strToCase’ has not been declared
atic bool qt_u_strToCase(const QString &str, QString *out, const QLocale &locale, Ptr_u_strToCase caseFunc)
tools/qlocale_icu.cpp: In function ‘bool qt_u_strToCase(const QString&, QString*, const QLocale&, int)’:
tools/qlocale_icu.cpp:186:46: error: ‘UChar’ does not name a type; did you mean ‘QChar’?
int32_t size = caseFunc(reinterpret_cast<UChar *>(result.data()), result.size(),
QChar
tools/qlocale_icu.cpp:186:52: error: expected ‘>’ before ‘*’ token
tools/qlocale_icu.cpp:186:52: error: expected ‘(’ before ‘*’ token
tools/qlocale_icu.cpp:186:53: error: expected primary-expression before ‘>’ token
tools/qlocale_icu.cpp:187:36: error: ISO C++ forbids declaration of ‘type name’ with no type [-fpermissive]
reinterpret_cast<const UChar *>(str.constData()), str.size(),
tools/qlocale_icu.cpp:187:36: error: expected ‘>’ before ‘UChar’
tools/qlocale_icu.cpp:187:36: error: expected ‘(’ before ‘UChar’
tools/qlocale_icu.cpp:187:36: error: ‘UChar’ was not declared in this scope
tools/qlocale_icu.cpp:187:36: note: suggested alternative: ‘QChar’
QChar
tools/qlocale_icu.cpp:187:43: error: expected primary-expression before ‘>’ token
tools/qlocale_icu.cpp:188:64: error: expected ‘)’ before ‘;’ token
locale.bcp47Name().toLatin1().constData(), &status);
tools/qlocale_icu.cpp:200:42: error: ‘UChar’ does not name a type; did you mean ‘QChar’?
QChar
tools/qlocale_icu.cpp:200:48: error: expected ‘>’ before ‘*’ token
tools/qlocale_icu.cpp:200:48: error: expected ‘(’ before ‘*’ token
tools/qlocale_icu.cpp:200:49: error: expected primary-expression before ‘>’ token
tools/qlocale_icu.cpp:201:36: error: ISO C++ forbids declaration of ‘type name’ with no type [-fpermissive]
tools/qlocale_icu.cpp:201:36: error: expected ‘>’ before ‘UChar’
tools/qlocale_icu.cpp:201:36: error: expected ‘(’ before ‘UChar’
tools/qlocale_icu.cpp:201:43: error: expected primary-expression before ‘>’ token
tools/qlocale_icu.cpp:202:64: error: expected ‘)’ before ‘;’ token
tools/qlocale_icu.cpp: In function ‘bool qt_u_strToUpper(const QString&, QString*, const QLocale&)’:
tools/qlocale_icu.cpp:218:45: error: ‘ptr_u_strToUpper’ was not declared in this scope
return qt_u_strToCase(str, out, locale, ptr_u_strToUpper);
tools/qlocale_icu.cpp:218:45: note: suggested alternative: ‘qt_u_strToUpper’
qt_u_strToUpper
tools/qlocale_icu.cpp: In function ‘bool qt_u_strToLower(const QString&, QString*, const QLocale&)’:
tools/qlocale_icu.cpp:223:45: error: ‘ptr_u_strToLower’ was not declared in this scope
return qt_u_strToCase(str, out, locale, ptr_u_strToLower);
tools/qlocale_icu.cpp:223:45: note: suggested alternative: ‘qt_u_strToLower’
qt_u_strToLower
Makefile:14356: recipe for target '.obj/release-static/qlocale_icu.o' failed
make[1]: *** [.obj/release-static/qlocale_icu.o] Error 1
make[1]: *** Waiting for unfinished jobs....
make[1]: Leaving directory '/tmp/luxbuild/qt-everywhere-opensource-src-4.8.6/src/corelib'
Makefile:194: recipe for target 'sub-corelib-make_default-ordered' failed
make: *** [sub-corelib-make_default-ordered] Error 2
!!! Qt compilation failed
What can I do in order to be able to compile in Ubuntu 18.04?
The same happens if I try to compile the master branch.
Thanks in advance for your help.
