Page 5 of 6
Re: Network rendering support
Posted: Tue Jan 30, 2018 10:24 pm
by jensverwiebe
Sharlybg wrote: ↑Tue Jan 30, 2018 10:18 pm
Just forget to ask and propose if possible :
__ i don't know the GUI tools behind blender and old luxrender UI but assume the licence here must bring what we need.
Blender has an completely own gui written with ogl draws ( ghost ) and i fear Qt along with apache might be incompatible.
I may be wrong with the latter.
IMGui might be it as we already use it, have experience with and i saw really complex programs done with it.
Jens
Posted: Sun Feb 04, 2018 2:05 pm
by jensverwiebe
Followup from the alpha3 announce discussion:
This is what i do atm to keep the package small and keep a good overlook ( wip ):
1: have a simplified dir:
( luxcoreui has now an '$ORIGIN/lib' rpath ! , pyluxcorebla.py's are included in /lib )
2: Use one cmd script ( could be a binary as well ) to acces all cmd's ( todo: merger, done ):
#!/bin/bash
sleep 0.2 # just to let the terminal appear and become active
wmctrl -r :ACTIVE: -e 5,0,0,860,440 # set left/top, experimental
function jumpto
label=$1
cmd=$(sed -n "/$label:/{:a;n;p;ba};" $0 | grep -v ':$')
eval "$cmd"
exit
start=${1:-"start"}
filename=${1:-"filename"}
jumpto $start
start:
pause=0
echo Choose task: [S]ingleConsole \ Net[C]onsole \ Net[N]ode \ [M]erge \( Leave empty to abort \)
read task
case "$task" in
"") echo "Canceled by user ..."; sleep 1; exit
S|s) echo "Setup Console"
action=console
C|c) echo "Setup NetConsole"
action=netconsole
N|n) echo "Setup NetNode"
action=netnode
M|m) echo "Setup Merge"
action=merge
*) echo "Invalid choice ..."; sleep 1; jumpto $start
esac
echo Set extra arguments here \(-h shows helpchart\) \( + return \)
read args
if [ $args == "" ]; then
echo "No arguments"
else
echo "Arguments: $args"
fi
if [ "$args" == "-h" ]; then
pause=10
echo "Holding help-page for $pause seconds"
elif [ "$task" == "m" ]; then
pause=3
echo "Holding result-page for $pause seconds"
fi
filename:
if [[ "$task" != "n" && "$args" != "-h" ]]; then
echo "Drop or type path(s) to file(s)"
read filepath
if [ "$filepath" == "" ]
then echo "Missing file(s), try again ..."; jumpto $filename
fi
fi
echo Starting $action
gnome-terminal -e '/bin/bash -c "python3 ./lib/pyluxcore'$action'.py '"$args"' '"$filepath"'; sleep '$pause'" '
jumpto $start
Remark: the sleeps are needed to keep the helppage open a while.
This package is much smaller than the orig. alpha3 ( 90mb vs. 220mb uncompressed, 24mb vs. 140mb bz2 compressed )
and does not need any install. I have already some rework in mind, is on todo.
EDIT: did a few optimizations, added merger
Jens
Posted: Thu Oct 04, 2018 2:45 pm
- I have done the first rendering with a AWS EC2 node in the mix. I was using my home i7 3930K+i7 860 and a remote Intel(R) Xeon(R) CPU E5-2666 v3 @ 2.90GHz (I think it has 18 cores/36 threads) with 60GB ram from AWS Frankfurt data center. The network rendering seems to works well even over internet: It was transferring a 1024x1024 film in less than 2 seconds.
The rendering speed of the AWS Xeon isn't very impressive (even if I like to compile LuxCore with a "make -j 36"
) however, the point here is that you can literally lunch any number of AWS EC2 instances you want/can pay.
Hi Dade ! do you think we can render Animation now with AWS EC2 and Luxcore now ?
And What the steps if it is possible ?
Posted: Thu Oct 04, 2018 3:46 pm
Sharlybg wrote: ↑Thu Oct 04, 2018 2:45 pm
It is possible but renting one or more high end machine on AWS is quite expansive (and complex). AWS is not intended for end-user usage and you need some good know-how to be able to handle VM creation, etc. on your own.
You can find the prices here:
https://aws.amazon.com/ec2/pricing/on-demand/
The point would be to use Spot instances instead of normal one (there is a huge discount), however all the management is quite complex (i.e. someone would have to setup a render farm service and than sell the service so the end-user would see only a front-end and not the AWS back-end).
Posted: Thu Oct 04, 2018 4:13 pm
Renderbot ? any possibility to add Luxcore 2.0 support ?
http://renderbot.net/
Posted: Thu Oct 04, 2018 4:30 pm
Sharlybg wrote: ↑Thu Oct 04, 2018 4:13 pm
Yes, but has it been abandoned ?
Posted: Fri Oct 05, 2018 11:22 am
No but it is only for cycles render.
I really want to try following a steps by steps instructions from you or BYOB to be able to set VM for Luxcore.
Posted: Fri Oct 05, 2018 12:10 pm
I've created my account on AWS. They want me to select an AMI. Going to learn and familliarize a bit with it.
Posted: Fri Oct 05, 2018 1:33 pm
Sharlybg wrote: ↑Fri Oct 05, 2018 12:10 pm
You can use a standard Ubuntu 14.04LTS or 16, install standalone LuxCore and use the command line tools.
Posted: Fri Oct 05, 2018 1:47 pm
i'm already connected to a Window server ( fear a bit about linux , not a great expert of it ). i had follow the instructions on the Website and manage to connect to the remote instance ( the free one t2 micro ). they suggest me to create a second administrator account for backup if error occur , wich i finally get done.
The remote windows desktop is open. now i need to install blender 2.79b and luxcore alpha 4 normally ?
