BlendLuxCore Particles support
Re: BlendLuxCore Particles support
Post by B.Y.O.B. » Sat Jan 13, 2018 10:40 pm
I did some more work on particle/emitter visibility and updates during viewport render.
I think we can merge the branch into master.
There is still one bug during viewport render: when the number of particles is lowered, they are not deleted from the luxcore_scene.
However I don't think it's worth to fix this currently, it would require us to keep track of every particle in python which might slow things down again (and consumes memory).
And since a simple restart of the viewport render fixes it, I'd leave it like it is for now.
Post by Sharlybg » Sun Jan 14, 2018 9:50 am
So can you make the viewport render restart automatic when particles setting require it until the fix.this way we do not have to update it manually by switching between shading mod ?
Post by B.Y.O.B. » Sun Jan 14, 2018 10:00 am
To do that I would need the same info as for the fix ("particle x vanished"). And if I had that info, I could just fix it.
wasd
Post by wasd » Thu Nov 15, 2018 2:55 am
I have a question: does luxcore support particles motion blur now?
CPU Bidir + Metropolis | Log Power | Core i5-4570
Post by B.Y.O.B. » Thu Nov 15, 2018 8:52 am
No, but I am very sure this will be very easy to do once I port the addon to Blender 2.8.
