OIDN new version Out
Odilkhan Yakubov
Re: OIDN new version Out
Post by Odilkhan Yakubov »
1. Yes. It is properly installed and worked fine before I removed and copied/pasted you have been mentioned files.
2. I removed that files which you posted on your screenshots.
OS: Windows 10 Pro x64;
Blender version: v2.83.12 LTS (latest);
Here a screenshot from error:
Odilkhan Yakubov wrote: Tue Feb 16, 2021 3:36 pm 1. Yes. It is properly installed and worked fine before I removed and copied/pasted you have been mentioned files.
IDK, I think something else is a miss.
Care to check on a fresh, clean, default portable standalone installation just to be sure nothing (old preferences or startup) is interfering.
I've seen that sometimes even installing Blender via auto-installer (.exe) can cause issues.
Odilkhan Yakubov
kintuX wrote: Fri Feb 19, 2021 11:49 am
Really dont know. From other hand I started using SuperImageDenoiser addon by Kevin Lorengel. Here a link if you're interesting:
Martini
Post by Martini »
Odilkhan Yakubov wrote: Tue Feb 16, 2021 3:36 pm 2. I removed that files which you posted on your screenshots.
Make sure you remove only those files. There are a bunch of other files in there too, and they're all required to be there.
Also, make sure Blender is closed when you try to remove those files because you cannot delete them if they are in use by LuxCore.
You should be left with:
embree3.dll
get_binaries.py
nvrtc64_101_0.dll
oidnDenoise.exe      <- new
OpenImageDenoise.dll <- new
OpenImageIO.dll
pyluxcore.pyd
pyluxcoretool.exe
pyluxcoretools.zip
readme.md
tbb12.dll            <- new
Works for me on Blender 2.83.12 and 2.91.2
Odilkhan Yakubov
Martini wrote: Sun Feb 21, 2021 10:44 am
embree3.dll
get_binaries.py
nvrtc64_101_0.dll
OpenImageIO.dll
pyluxcore.pyd
pyluxcoretool.exe
pyluxcoretools.zip
readme.md
tbb12.dll            <- new
This is what i've done exactly as you poated here too.
juangea
Post by juangea »
Have you replaced those with the newer version?
AndreasResch
Post by AndreasResch »
For me it worked. Just delete the 3 files - oidnDenoise.exe, OpenImageDenoise.dll and tbb.dll. Copy the new ones into the directory. The file "tbb12.dll" has a different name now though.
AndreasResch
Just compared V1.3 to the one coming with the latest beta of LuxcoreBlender and the results are very promising. V1.3 retains a lot more details and looks cleaner.
Here are two images to compare - the lower one is V1.3.
zuljin3d
Post by zuljin3d »
AndreasResch wrote: Thu Feb 25, 2021 1:11 pm For me it worked. Just delete the 3 files - oidnDenoise.exe, OpenImageDenoise.dll and tbb.dll. Copy the new ones into the directory. The file "tbb12.dll" has a different name now though.
did everything as you wrote, it still does not work.
blenderluxcore just turns off :?
AndreasResch
Can you post a screenshot of the BlendLuxCore bin directory?
