exr image output
bartek_zgo
Re: exr image output
Post by bartek_zgo »
Thanks CodeHD for you answer.
Does it mean that I only need to add TONEMAP_LINEAR to image pipeline and scale it with 0.39 factor?
No, the factor 0.39 was the ratio between the scale factors for different gamma, not the scale factor itself. At gamma 2.2, this evaluates to 2.465e-4.
CodeHD wrote: Wed Nov 25, 2020 12:09 pm If we compute the ratio of this factor for gamma 2.2 and 1.0 we get 0.39.
It is not a linear space. A fixed scale can not fix the problem but I assume it is exactly what you are trying to show.
Dade wrote: Wed Nov 25, 2020 12:54 pm It is not a linear space. A fixed scale can not fix the problem but I assume it is exactly what you are trying to show.
Yes, the factor 0.39 is specific to the LUXLINEAR tonemapper when comparing between gamma 1.0 and 2.2.
bartek_zgo
Thanks a lot CodeHD. Your solution is exactly what I needed. Finally exr is identical to png
I post the final pipeline code. Maybe someone will have the same problem
film.imagepipelines.1.0.type = "NOP"
film.imagepipelines.1.1.type = "NOP"
film.imagepipelines.1.2.type = "TONEMAP_LUXLINEAR"
film.imagepipelines.1.2.sensitivity = "100"
film.imagepipelines.1.2.exposure = 0.1
film.imagepipelines.1.2.fstop = 22
film.imagepipelines.1.3.type = "GAMMA_CORRECTION"
film.imagepipelines.1.3.value = "2.2"
film.outputs.2.type = "RGB_IMAGEPIPELINE"
film.outputs.2.index = 1
film.outputs.2.filename = "c:\Bartek\stack\LuxCoreTests\exrGammaProblems\rgb_g22.png"
film.imagepipelines.3.0.type = "NOP"
film.imagepipelines.3.1.type = "NOP"
film.imagepipelines.3.2.type = "TONEMAP_LUXLINEAR"
film.imagepipelines.3.2.sensitivity = "100"
film.imagepipelines.3.2.exposure = 0.1
film.imagepipelines.3.2.fstop = 22
film.imagepipelines.3.3.type = "TONEMAP_LINEAR"
film.imagepipelines.3.3.scale = "0.39"
film.outputs.6.type = "RGB_IMAGEPIPELINE"
film.outputs.6.index = 3
film.outputs.6.filename = "c:\Bartek\stack\LuxCoreTests\exrGammaProblems\rgb_noGamma_tonemaper.exr"
