Yes, I have to admit I kind of forgot about this.
UVRandomMapping2D (and LocalRandomMapping3D)
Re: UVRandomMapping2D (and LocalRandomMapping3D)
Not a problem, we are here to remind and ask hahaha
I have added support for UVRandomMapping2D to the Blender addon.
You can find it in the "Type" dropdown in the 2D mapping node.
LocalRandomMapping3D still to do.
- Attachments
- random_uv.blend
- (883.41 KiB) Downloaded 1 time
Woooohooo! That's awesome. I'm sure that I'm not the only one who will appreciate this. With that checked off of the list, the bevel shader is the last position that would enable me to transfer my projects to Luxcore. But this is a huge step in that direction.
Thanks, man.
Thanks, man.
What's the proper way to download this version of the addon? Will Luxcore V2.5 Beta1 be sufficient for this feature?
EDIT: Nevermind. I think I figured it out. Going to Coce->Download ZIP should be OK, right?
No, downloading the zip is not enough, because it doesn't contain the LuxCore binaries.AndreasResch wrote: ↑Tue Feb 23, 2021 1:13 pmWhat's the proper way to download this version of the addon? Will Luxcore V2.5 Beta1 be sufficient for this feature?
Go to the latest release here and open the assets dropdown: https://github.com/LuxCoreRender/BlendLuxCore/releases
Ah - OK. I've overseen that little dropdown. Cheers.
Works like a charm. Together with the Triplanar Mapping node this beats Cycles in usability. Awesome - Thanks again.
