Histogram-preserving Blending for Randomized Texture Tiling (aka Procedural stochastic texturing)
Re: Histogram-preserving Blending for Randomized Texture Tiling (aka Procedural stochastic texturing)
Post by Dade » Thu Aug 27, 2020 9:15 pm
Rsharma wrote:
Thu Aug 27, 2020 9:10 pm
This research is from Brent Burley and Eric Heitz not Benedict.
http://jcgt.org/published/0008/04/02/
https://eheitzresearch.wordpress.com/722-2/
Please credit them.
I credited the right paper but the wrong author. I was assuming the author of the WebGL demo was the same of the paper.
Rsharma
Post by Rsharma » Thu Aug 27, 2020 9:23 pm
Please credit them.
Thank you for fixing it! Great implementation btw!
Post by Dade » Thu Aug 27, 2020 9:35 pm
kintuX wrote:
Thu Aug 27, 2020 4:45 pm
BTW
Are there any plans for custom controls like U&V offset, rotation & scale, amount and type of blending?
Here's corona's version for example
I'm not sure if they can be of any real use or just clutter the UI. Our current defaults (Randomize tiles on, 3 tiles, high quality blending, exponential blending) should be good for all seasons. Did you find some alternatively useful setup ?
AndreasResch
Post by AndreasResch » Fri Aug 28, 2020 2:33 pm
Good looking and a necessary addition. 8-)
BTW
Count me in for that. This would be amazing and add so much more variance to scenes if necessary. In Blender I use UV randomization all the time. This and the Bevel Shader (which I see you are already working on) would be awesome improvements.
AndreasResch
Post by AndreasResch » Fri Aug 28, 2020 2:40 pm
BTW
Here's an example where randomized UV rotation comes in very handy. This are instances of the same object (same material of course) and all the wood grain is oriented differently, as it is in real life. I sometimes have dozens of them in scenes and this variance makes all the difference.
Post by Dade » Fri Aug 28, 2020 3:11 pm
Ok but I was talking of the "Tiling" section of the UI panel: Randomized UV and Randomized Tiling are somewhat 2 separate and uncorrelated topics.
AndreasResch
Post by AndreasResch » Fri Aug 28, 2020 3:20 pm
I understand. But if you look at that Randomization dialog from Corona, it has a randomize option for the W axis. So with 1 tile and W randomization turned on, you will get the same result, right? Having some randomization in the Triplanar Mapping node would do the job as well.
Post by Dade » Sun Aug 30, 2020 12:13 pm
The support for CPUs and GPUs rendering should be now complete.
Post by Sharlybg » Sun Aug 30, 2020 3:35 pm
Awesome :geek:
