Hi
Is it possible to add connection between LuxCore and Native Cycles denoiser?
NLM is much cleaner then OptiX or OIDIN denoisers
and what is need is just special passes for him
IMHO it raise up integration of Cycles and LuxCore
and level of LuxCore render pictures
Re: LuxCore and Native Cycles denoiser
LuxCore has similar denoiser like NLM from Cycles and it's called BCD. Just choose it from the Render Proporties > Denoiser > Type > BCD.
may be you can say values of BSD denoiser params to get the same result as NLM or nearby
I don't think this is possible with reasonable effort.
thank you for answer
