New Reflect/Transmit AOVs
Re: New Reflect/Transmit AOVs
Thanks, now the AOVs are created correctly by the addon.
Hello, can you share the shader ball scene? I'm having trouble getting the same result with another scene.Dade wrote: Fri Aug 21, 2020 10:53 am rr.jpg
The limit of 32 AOV types has been lifted (we were at the cap) and the support for new Reflect/Transmit AOVs has been added:
DIRECT_DIFFUSE_REFLECT
DIRECT_DIFFUSE_TRANSMIT
DIRECT_GLOSSY_REFLECT
DIRECT_GLOSSY_TRANSMIT
INDIRECT_DIFFUSE_REFLECT
INDIRECT_DIFFUSE_TRANSMIT
INDIRECT_GLOSSY_REFLECT
INDIRECT_GLOSSY_TRANSMIT
INDIRECT_SPECULAR_REFLECT
INDIRECT_SPECULAR_TRANSMIT
They are the result of splitting reflections/transmissions of already available AOVs:
DIRECT_DIFFUSE = DIRECT_DIFFUSE_REFLECT + DIRECT_DIFFUSE_TRANSMIT
DIRECT_GLOSSY = DIRECT_GLOSSY_REFLECT + DIRECT_GLOSSY_TRANSMIT
INDIRECT_DIFFUSE = INDIRECT_DIFFUSE_REFLECT + INDIRECT_DIFFUSE_TRANSMIT
INDIRECT_GLOSSY = INDIRECT_GLOSSY_REFLECT + INDIRECT_GLOSSY_TRANSMIT
INDIRECT_SPECULAR = INDIRECT_SPECULAR_REFLECT + INDIRECT_SPECULAR_TRANSMIT
Thank you.
Thank you.
