New Reflect/Transmit AOVs
Re: New Reflect/Transmit AOVs
Post by B.Y.O.B. » Wed Aug 26, 2020 10:35 pm
Thanks, now the AOVs are created correctly by the addon.
JulianoLisboa
Post by JulianoLisboa » Thu Aug 27, 2020 6:45 pm
Dade wrote:
Fri Aug 21, 2020 10:53 am
The limit of 32 AOV types has been lifted (we were at the cap) and the support for new Reflect/Transmit AOVs has been added:
DIRECT_DIFFUSE_REFLECT
DIRECT_DIFFUSE_TRANSMIT
DIRECT_GLOSSY_REFLECT
DIRECT_GLOSSY_TRANSMIT
INDIRECT_DIFFUSE_REFLECT
INDIRECT_DIFFUSE_TRANSMIT
INDIRECT_GLOSSY_REFLECT
INDIRECT_GLOSSY_TRANSMIT
INDIRECT_SPECULAR_REFLECT
INDIRECT_SPECULAR_TRANSMIT
They are the result of splitting reflections/transmissions of already available AOVs:
DIRECT_DIFFUSE = DIRECT_DIFFUSE_REFLECT + DIRECT_DIFFUSE_TRANSMIT
DIRECT_GLOSSY = DIRECT_GLOSSY_REFLECT + DIRECT_GLOSSY_TRANSMIT
INDIRECT_DIFFUSE = INDIRECT_DIFFUSE_REFLECT + INDIRECT_DIFFUSE_TRANSMIT
INDIRECT_GLOSSY = INDIRECT_GLOSSY_REFLECT + INDIRECT_GLOSSY_TRANSMIT
INDIRECT_SPECULAR = INDIRECT_SPECULAR_REFLECT + INDIRECT_SPECULAR_TRANSMIT
Hello, can you share the shader ball scene? I'm having trouble getting the same result with another scene.
Thank you.
Thank you.
