OpenCL Kernel Compilation
Continuum
Post by Continuum » Tue Aug 18, 2020 9:43 am
I was curious if it was possible to compile the kernels before rendering in the API (v2.4), or is a there a way to know when the kernels are compiling so I can display the appropriate message? I noticed the blender addon is able to do something like this.
Re: OpenCL Kernel Compilation
Post by Dade » Tue Aug 18, 2020 10:58 am
Not really with OpenCL. It would be using SPIR-V but, as far as I know, it is not supported by NVIDIA (70%+ of GPUs sold).
It is possible with CUDA but requires some work.
You can use this LuxCore API method to know if a (long) kernel compilation time is going to be required for the rendering: https://github.com/LuxCoreRender/LuxCor ... re.h#L1233
Post by B.Y.O.B. » Tue Aug 18, 2020 11:08 am
In the BlendLuxCore addon I do it here for the viewport: https://github.com/LuxCoreRender/BlendL ... rt.py#L109
Continuum
Post by Continuum » Tue Aug 18, 2020 5:25 pm
Okay thank you very much for the quick response, this should do the trick, will play around with this. For now just focusing on OpenCL, will focus on CUDA later.
