Wireframe texture
Re: Wireframe texture
Post by B.Y.O.B. » Wed Jan 27, 2021 10:36 pm
Dade wrote:
Wed Jan 27, 2021 8:09 pm
This is something can only be done at BlendLuxCore level because, for the time LuxCore receives the mesh, it has already been tessellated in triangles and any previous information about where the mesh coming from is not included.
I'm not even sure it is possible win BlendLuxcore:
It should be possible, maybe in pyluxcore::DefineBlenderMesh(), if I'm not mistaken.
But it's a very minor feature, so I won't put it on my Todo list for now. Anyone else is welcome to implement it of course.
Post by Dade » Wed Jan 27, 2021 11:23 pm
If you have the information required, it is possible, you have just to set the vertex AOVs used by wireframe texture in BlendLuxCore instead of using the Shape to automatically create them.
Post by CodeHD » Thu Jan 28, 2021 11:11 am
Just a thought in case this does get implemented eventaully On the corona example:
I notice that the rendered teapot in corona has curved wireframe lines. Since that would not be the case with triangles as large as shown in the model, an equivalent feature probably needs to take subdivision modifiers into account.
Post by Dade » Thu Jan 28, 2021 12:03 pm
Actually, Corona looks to me like it is just using a texture and is not related to the underlaying mesh at all :?:
Post by CodeHD » Thu Jan 28, 2021 3:58 pm
Your're right. The edges in the render and UI screenshot looked identical at first glance (except the curvature), but they do appear to be slightly different in location.
JulianoLisboa
Post by JulianoLisboa » Tue Feb 02, 2021 1:28 pm
Hello, what's up? And the shader bevel, how is it?
