Page 3 of 4
Re: Camera non uniform bokeh support
Posted: Wed Jul 29, 2020 4:16 pm
Dade wrote: ↑Wed Jul 29, 2020 12:20 pm
Dade wrote: ↑Wed Jul 29, 2020 10:25 am
P.S. chafouin, after having seen your link to
http://richardrosenman.com/shop/dof-pro, I have changed my mind and I will add the support for bokeh with custom images ... this stuff is too cool.
HAHA, how crazy is this thing
I added the support for bokeh custom distribution...
Note: I have written the CPU code, I have still to write the GPU one.
Will there be RGB tex support or BW/grayscale only?
Note: RGB support also allows creation of chromatic aberration for that extra realistic touch. And becomes especially valuable when you know about
Out-of-focus point spread functions (paper)
Posted: Wed Jul 29, 2020 6:06 pm
kintuX wrote: ↑Wed Jul 29, 2020 4:16 pm
It is a weight so it is gray scale only.
The paper seems impossible to download.
Posted: Wed Jul 29, 2020 6:10 pm
by chafouin
This is awesome!
I think RGB bokeh shape would be nice to have, but if you get proper longitudinal achromatic aberration in front and back bokeh, as well as chromatic aberration (that you already added in the imagepipeline), this is less required.
Posted: Wed Jul 29, 2020 7:05 pm
Dade wrote: ↑Wed Jul 29, 2020 6:06 pm
Strange
maybe it takes some time... anyways I re-hosted it on
wetransfer - OOF PSF ~10MB (slides & paper)
Original source @
http://aggregate.org/
February 4-5, 2014 Prof. Dietz presented two papers and a research exhibit at the SPIE Electronic Imaging conference: Out-of-focus point spread functions (
slides,
full paper) and Frameless, time domain continuous image capture (slides, full paper).
Edit/
Here's an example made with Corona
- input image
- render
Posted: Wed Jul 29, 2020 9:08 pm
by chafouin
While it can fake chromatic aberrations and has been used in the past in many engines, it is not the correct and physical way to create chromatic or achromatic aberrations.
The current color aberrations only allow for purple and green, while these are usually more red and blue. Is it possible to give control over the affected channels?
Green and purple are more visible in achromatic aberrations (front/back focus bokeh) which adds a lot of realism to scenes. This plus optical vignetting (cat's eye effect) and tangential astigmatism (swirly bokeh), and you get everything you need to recreate a lens.
Purple fringing created by digital sensors are created in areas of high contrasts and can be done in compositing, but it could be nice to have it in the image pipeline as well. Soft corners is also a simple effect but could be added to the image pipeline. Then we can start making lens presets with different visual signatures
Posted: Thu Jul 30, 2020 10:52 am
It seems to me like an RGB bokeh image makes no sense if you want to emulate chromatic aberration, because getting color shifts from an RGB image would mean that it is constant over the whole film plane, which is not the case in realistic chromatic aberration.
On another note, having the "cat-eye" effect for bokeh would be a nice feature as well, not sure how hard that would be to add. Is the sample position on the film plane known when evaluating the bokeh distribution?
Posted: Thu Jul 30, 2020 11:16 am
by jgrover110
Longitudinal chromatic aberration needs that colour fringing around the bokeh, and for it to shift depending on the distance from the focal point. Hopefully this is possible as the effect is very realistic
Posted: Thu Jul 30, 2020 1:36 pm
I added the support for custom bokeh to GPU code.
About bokeh chromatic aberation: current internal camera interface only returns a ray (not a color) so it is not possible to have chromatic aberation inside the boundary of the current interface. Indeed, the interface can be extend, but it is more work.
Posted: Thu Jul 30, 2020 2:57 pm
Dade wrote: ↑Thu Jul 30, 2020 1:36 pm
Thank you.
About bokeh chromatic aberration: current internal camera interface only returns a ray (not a color) so it is not possible to have chromatic aberration inside the boundary of the current interface. Indeed, the interface can be extend, but it is more work.
Yup, that's how everyone does it, except Corona.
B.Y.O.B. wrote: ↑Thu Jul 30, 2020 10:52 am
True, the best would be something alike
Lentil - Lenses for Path Tracers (for Arnold)*.
Still, so called "RGB bokeh" is second best as it can create lens FX in "visual accordance" to camera settings which takes focal point, DOF, film size, aperture image, dirt map... all into account and could even generate flare and glare. Also, it's dumb simple to use.
But indeed for time being, out-of-scope for LuxCore.
Edit:
Lentil is an evolution of
POTA (Polynomial Optics To Arnold) an open source camera shader... based on
2016 Sparse high-degree polynomials for wide-angle lenses (paper)
Posted: Sat Aug 01, 2020 4:34 pm
The Blender addon now has support for custom bokeh images.
