Page 1 of 3
New RTPATHOCL synchronization code
Posted: Sun Jun 07, 2020 2:05 pm
I have reworked RTPATHOCL synchronization code with the objective to remove UI lag. This work is on "new_rtpathocl_sync" branch.
@B.Y.O.B.: the WaitNewFrame() now takes zero time to be execute (be careful to not eat CPU time with too many refresh now). This should solve the problem of Blender UI lagging when doing view port rendering a complex scenes. Can you try it ?
Re: New RTPATHOCL synchronization code
Posted: Mon Jun 08, 2020 1:25 am
by u3dreal
All works on OSX..
Posted: Mon Jun 08, 2020 5:02 am
Dade wrote: ↑Sun Jun 07, 2020 2:05 pm
Wow, I hope this will help!
Posted: Wed Jun 10, 2020 9:16 am
Sounds good, I'll test it when I'm back at my PC in about one week.
Posted: Wed Jun 10, 2020 3:22 pm
by TAO
Sounds great.
Posted: Thu Jun 11, 2020 10:40 am
I merged the branch with the master so it can now be tested by anyone with the next automatic build.
Posted: Thu Jun 11, 2020 11:40 am
by juangea
Does this require changes in the addon or will it work in the next build out of the box?
Posted: Thu Jun 11, 2020 1:35 pm
juangea wrote: ↑Thu Jun 11, 2020 11:40 am
It should work out of the box, you may have somewhat the opposite problem: too many screen refreshes because they are not timed anymore.
Posted: Thu Jun 11, 2020 1:37 pm
BTW, is there any interest in adding CPU (i.e. hybrid => CPU+GPU) support for RTPATHOCL ? It may be helpful on high end CPUs where the CPU is about as fast as the GPU (i.e. RTPATHOCL is currently GPU-only rendering).
Posted: Thu Jun 11, 2020 5:26 pm
by TAO
It could be a good thing, especially with new high core CPUs generation.
I like the idea.
