Page 5 of 11
Posted: Sun Aug 23, 2020 6:35 pm
kevzor wrote: ↑Sun Aug 23, 2020 6:26 pm
Sharlybg wrote: ↑Sun Aug 23, 2020 2:38 pm
What blendluxcore version do you have ?
You need 2.5 lastest.
Sometime you need to restart blender after installation and first attempt.
Thanks! I've downloaded the lastest one, which I only can see is 2.4. It also says LOL should be included in that one. Where can I find 2.5?
Thanks!
Installation and update is explained here at the begining. :
https://youtu.be/fJoqOqQIBgs
Lastest 2.5 blendluxcore :
https://github.com/LuxCoreRender/BlendL ... tag/latest
Posted: Sun Aug 23, 2020 9:12 pm
by neo2068
There is no break in compatibility on the server. It is likely the initial download problem with the IP blocking because of the many connections we talked about a few days ago.
Posted: Wed Sep 02, 2020 1:58 pm
Upcoming kitchen ware assets
Posted: Wed Sep 02, 2020 6:06 pm
Looking good
Posted: Thu Sep 03, 2020 5:13 pm
B.Y.O.B. wrote: ↑Wed Sep 02, 2020 6:06 pmLooking good
thanks ! still growing
Posted: Fri Sep 04, 2020 7:41 am
by Harvester
Fantastic! Thank you.
Posted: Wed Sep 09, 2020 4:05 pm
by Harvester
Hi Sharlybg. I wish to ask you something about the "installation" of LOL in Blender. LuxCore Render 2.4 official is installed and working as expected under Blender 2.83.5 (.6 in a few minutes) portable; a common folder was created locally (D:\Blender Projects\Library\LuxCoreOnlineLibrary_data\) where I copied only the .blend files I received (as suggested in the zip file), being a Patreon supporter, inside the ...\model folder (the path is as above).
Now, I am not sure at all that all those models are being listed properly in the Asset Bar, furthermore, if I hover the mouse on the thumbnails I don't see any "description" below each asset, as it happens with the BlenderKit add-on.
Am I doing it right? Shall I switch to LuxCore Render 2.5 dev edition? Shall I register online on Draviastudio's website to have the LOL working properly? Shall I import/download all the currently available assets to have them ready available in the above mentioned library folder, or is there a way to batch download them locally?
Sorry for all these questions but I wish to get LCR and LOL working correctly and smoothly. Thank you in advance.
Posted: Wed Sep 09, 2020 6:15 pm
Patron asset features has been added in 2.5 Blendluxcore so you need that version to make it work properly as said in the tutorial here :
I don't if it is safe but blendluxcore 2.4 + Luxcore 2.5 build can make the trick (but forget about it and go for 2.5 build
Posted: Thu Sep 10, 2020 8:02 am
by Harvester
Thank you, I will follow your instructions.
Posted: Sat Sep 12, 2020 4:08 pm
Kitchen machine and ustensils are joining the party
Stunning 5 mn render on CPU.
Blenderartists topic : https://blenderartists.org/t/kitchen-ware-lol/1252973
Patreon assets here : https://www.patreon.com/Draviastudio
