LuxCore Online Library (LOL)
Post by Sharlybg » Sun Aug 23, 2020 6:35 pm
kevzor wrote:
Sun Aug 23, 2020 6:26 pm
Sharlybg wrote:
Sun Aug 23, 2020 2:38 pm
What blendluxcore version do you have ?
You need 2.5 lastest.
Sometime you need to restart blender after installation and first attempt.
Thanks! I've downloaded the lastest one, which I only can see is 2.4. It also says LOL should be included in that one. Where can I find 2.5?
Thanks!
Installation and update is explained here at the begining. :
https://youtu.be/fJoqOqQIBgs
Lastest 2.5 blendluxcore :
https://github.com/LuxCoreRender/BlendL ... tag/latest
neo2068
Post by neo2068 » Sun Aug 23, 2020 9:12 pm
Dade wrote:
Sun Aug 23, 2020 4:51 pm
@Neo2068, are you keeping different LoL versions on the server ? I have the feeling the answer is no.
We should have:
- https://luxcorerender.org/lol/v2.4/
- https://luxcorerender.org/lol/v2.5/
- and so on
Otherwise newer versions are likely to break old one if we keep everything under https://luxcorerender.org/lol (this is what may happening here with the above problem).
To maintain compatibility we could have now: https://luxcorerender.org/lol/ (for v2.4) and https://luxcorerender.org/lol/v2.5/ (for v2.5 and so on).
There is no break in compatibility on the server. It is likely the initial download problem with the IP blocking because of the many connections we talked about a few days ago.
Post by Sharlybg » Wed Sep 02, 2020 1:58 pm
Upcoming kitchen ware assets :D
Post by B.Y.O.B. » Wed Sep 02, 2020 6:06 pm
Looking good :)
Post by Sharlybg » Thu Sep 03, 2020 5:13 pm
Looking good :)
thanks ! still growing ;)
Harvester
Post by Harvester » Fri Sep 04, 2020 7:41 am
Fantastic! Thank you.
Harvester
Post by Harvester » Wed Sep 09, 2020 4:05 pm
Hi Sharlybg. I wish to ask you something about the "installation" of LOL in Blender. LuxCore Render 2.4 official is installed and working as expected under Blender 2.83.5 (.6 in a few minutes) portable; a common folder was created locally (D:\Blender Projects\Library\LuxCoreOnlineLibrary_data\) where I copied only the .blend files I received (as suggested in the zip file), being a Patreon supporter, inside the ...\model folder (the path is as above).
Now, I am not sure at all that all those models are being listed properly in the Asset Bar, furthermore, if I hover the mouse on the thumbnails I don't see any "description" below each asset, as it happens with the BlenderKit add-on.
Am I doing it right? Shall I switch to LuxCore Render 2.5 dev edition? Shall I register online on Draviastudio's website to have the LOL working properly? Shall I import/download all the currently available assets to have them ready available in the above mentioned library folder, or is there a way to batch download them locally?
Sorry for all these questions but I wish to get LCR and LOL working correctly and smoothly. Thank you in advance.
Post by Sharlybg » Wed Sep 09, 2020 6:15 pm
Patron asset features has been added in 2.5 Blendluxcore so you need that version to make it work properly as said in the tutorial here :
I don't if it is safe but blendluxcore 2.4 + Luxcore 2.5 build can make the trick (but forget about it and go for 2.5 build :mrgreen: ).
Harvester
Post by Harvester » Thu Sep 10, 2020 8:02 am
Thank you, I will follow your instructions.
Post by Sharlybg » Sat Sep 12, 2020 4:08 pm
Kitchen machine and ustensils are joining the party :D
Stunning 5 mn render on CPU.
Blenderartists topic : https://blenderartists.org/t/kitchen-ware-lol/1252973
Patreon assets here : https://www.patreon.com/Draviastudio
