Unified executable (for CPU-only, OpenCL and CUDA)
acasta69
Re: Unified executable (for CPU-only, OpenCL and CUDA)
Post by acasta69 » Fri May 29, 2020 4:18 pm
u3dreal wrote:
Fri May 29, 2020 12:35 pm
No access to secure file for me .. should i merge ? otherwise no check possible. maybe you can check ..
For increased security, secure files and secret variables are never accessible to pull requests coming from forks.
If you prefer not to act directly on the master branch, you could create another branch in our repo: in that case everything should work.
u3dreal
Post by u3dreal » Fri May 29, 2020 4:53 pm
If you guys have no problem with me committing on my own .. i'm fine with that.
portfolio http://q3de.com/
Xeon X5650@4Ghz, 2x GTX 770 Phantom RX 5700 - Catalina / High Sierra, Windows 10, Ubuntu 18.04
Post by Dade » Fri May 29, 2020 7:11 pm
acasta69 wrote:
Fri May 29, 2020 4:10 pm
I have updated the azure pipeline files for Windows and it's running now. I'll check the binaries as soon as they are available.
About Linux: is it enough to build only the version with neither "opencl" nor "cuda" in the directory name?
Or do you need to modify the build scripts in the "LinuxCompile" repo?
I still need to check/update the Linux build process.
Post by Dade » Sun May 31, 2020 12:23 pm
I should have now updated everything and, yes, neither "opencl" nor "cuda" in the directory name are required anymore.
acasta69
Post by acasta69 » Sun May 31, 2020 2:51 pm
I have updated the Azure pipeline files.
BlendLuxCore seems already ok, no modification necessary.
u3dreal
Post by u3dreal » Sun May 31, 2020 4:16 pm
Hmm there are some errors on linux side ... but yes it builds but only linux-opencl ..
I would do it but i have no clue what files are needed for linux
acasta69
Post by acasta69 » Sun May 31, 2020 4:36 pm
Do you mean this one?
https://dev.azure.com/LuxCoreRender/Lux ... a591&l=429
Yes, the "linux64-opencl" archive does not exist any more, I'll remove it from the list.
But I don't see other problems, or have I missed something?
Edit: oh, I see, you probably mean the missing CUDA DLLs. Actually I'm not sure about that as well.
u3dreal
Post by u3dreal » Sun May 31, 2020 4:47 pm
jep
u3dreal
Post by u3dreal » Sun May 31, 2020 4:50 pm
well it should be the ones provided with luxcore archive
u3dreal
Post by u3dreal » Sun May 31, 2020 8:37 pm
No none is provided .. :(
