Unified executable (for CPU-only, OpenCL and CUDA)
u3dreal
Re: Unified executable (for CPU-only, OpenCL and CUDA)
Post by u3dreal » Thu May 28, 2020 9:35 pm
OK i copied ..
libnvrtc.dylib and versions
libnvrct-buildins.dylib and versions
in the luxcoreui dir
i renamed my cuda dir
cuda seems enabled but no cuda device found
[LuxRays][11.197] OpenCL support: enabled
[LuxRays][11.197] OpenCL Platform 0: Apple
[LuxRays][11.198] CUDA support: enabled
[LuxRays][11.198] Device 0 name: Native
[LuxRays][11.198] Device 0 type: NATIVE_THREAD
[LuxRays][11.198] Device 0 compute units: 1
[LuxRays][11.198] Device 0 preferred float vector width: 4
[LuxRays][11.198] Device 0 max allocable memory: 17592186044415MBytes
[LuxRays][11.198] Device 0 max allocable memory block size: 17592186044415MBytes
[LuxRays][11.198] Device 0 has out of core memory support: 0
[LuxRays][11.198] Device 1 name: Intel(R) Core(TM) i7-4850HQ CPU @ 2.30GHz
[LuxRays][11.198] Device 1 type: OPENCL_CPU
[LuxRays][11.198] Device 1 compute units: 8
[LuxRays][11.198] Device 1 preferred float vector width: 4
[LuxRays][11.198] Device 1 max allocable memory: 16384MBytes
[LuxRays][11.198] Device 1 max allocable memory block size: 4096MBytes
[LuxRays][11.198] Device 1 has out of core memory support: 0
[LuxRays][11.198] Device 2 name: Iris Pro
[LuxRays][11.198] Device 2 type: OPENCL_GPU
[LuxRays][11.198] Device 2 compute units: 40
[LuxRays][11.198] Device 2 preferred float vector width: 1
[LuxRays][11.198] Device 2 max allocable memory: 1536MBytes
[LuxRays][11.198] Device 2 max allocable memory block size: 384MBytes
[LuxRays][11.198] Device 2 has out of core memory support: 0
[LuxRays][11.198] Device 3 name: GeForce GT 750M
[LuxRays][11.198] Device 3 type: OPENCL_GPU
[LuxRays][11.198] Device 3 compute units: 2
[LuxRays][11.198] Device 3 preferred float vector width: 1
[LuxRays][11.198] Device 3 max allocable memory: 2048MBytes
[LuxRays][11.198] Device 3 max allocable memory block size: 512MBytes
[LuxRays][11.198] Device 3 has out of core memory support: 0
RenderSession starting error:
Hardware device selection string has the wrong length, must be 3 instead of 4
Where does lux look for the libs ??
portfolio http://q3de.com/
Xeon X5650@4Ghz, 2x GTX 770 Phantom RX 5700 - Catalina / High Sierra, Windows 10, Ubuntu 18.04
Post by Dade » Thu May 28, 2020 9:43 pm
acasta69 wrote:
Thu May 28, 2020 7:27 pm
Defining LUXRAYS_DISABLE_CUDA and LUXRAYS_DISABLE_OPENCL seems to have no effect: LuxCoreUI still allows to choose OCL render engines. I'll try to check why this happens.
Yes but it should have no device available at all for the rendering. I guess it could be removed from the menu too.
Post by Dade » Thu May 28, 2020 9:45 pm
u3dreal wrote:
Thu May 28, 2020 2:22 pm
which files are needed by lux then ??? only the installed driver ?So i will not have to add any .dylib files ?? And no patching :) That sounds unbelievable
This will make things alot easier ...
One thing is to compile from the source (nothing is required), another thing is to run the generated executable (drivers and DLLs are required).
Post by Dade » Thu May 28, 2020 9:51 pm
CUDA => https://github.com/LuxCoreRender/LuxCor ... w.cpp#L341
NVRTC => https://github.com/LuxCoreRender/LuxCor ... w.cpp#L634
OpenCL => https://github.com/LuxCoreRender/LuxCor ... w.cpp#L167
CUEW and CLEW are the same libraries used by Blender to dynamically load CUDA and OpenCL so if Blender works, Lux should work too however Blender doesn't use NVRTC (so it should be the only reason why Blender works and Lux doesn't).
Indeed, we can add additional paths where to search the DLLs.
u3dreal
Post by u3dreal » Thu May 28, 2020 9:55 pm
Does that mean cuda libs were found ?
[LuxRays][10.703] CUDA support: enabled
Post by Dade » Thu May 28, 2020 10:49 pm
No, it means the code has been compiled with CUDA support. You will have a:
CUDA support: available
After that line if CUDA has been also found: https://github.com/LuxCoreRender/LuxCor ... t.cpp#L104
u3dreal
Post by u3dreal » Thu May 28, 2020 11:25 pm
Does luxcore look in the directory it is in ? or will we have to add that manually .
like @rpath for osx ?
u3dreal
Post by u3dreal » Fri May 29, 2020 9:37 am
cool adding @executable_path makes luxcoreui work ... so i guess i will just add the other paths for the bundle and pyluxcore ... i guess it uses the same paths Wow that makes the compiling on azure really easy ... just copy the libs ...
[LuxRays][19.683] OpenCL support: enabled
[LuxRays][19.683] OpenCL Platform 0: Apple
[LuxRays][19.683] CUDA support: enabled
[LuxRays][19.683] CUDA support: available
[LuxRays][19.683] CUDA driver version: 10.10
[LuxRays][19.683] CUDA device count: 1
[LuxRays][19.683] Device 0 name: Native
[LuxRays][19.683] Device 0 type: NATIVE_THREAD
[LuxRays][19.683] Device 0 compute units: 1
[LuxRays][19.683] Device 0 preferred float vector width: 4
[LuxRays][19.683] Device 0 max allocable memory: 17592186044415MBytes
[LuxRays][19.683] Device 0 max allocable memory block size: 17592186044415MBytes
[LuxRays][19.683] Device 0 has out of core memory support: 0
[LuxRays][19.683] Device 1 name: Intel(R) Core(TM) i7-4850HQ CPU @ 2.30GHz
[LuxRays][19.683] Device 1 type: OPENCL_CPU
[LuxRays][19.683] Device 1 compute units: 8
[LuxRays][19.683] Device 1 preferred float vector width: 4
[LuxRays][19.683] Device 1 max allocable memory: 16384MBytes
[LuxRays][19.683] Device 1 max allocable memory block size: 4096MBytes
[LuxRays][19.683] Device 1 has out of core memory support: 0
[LuxRays][19.683] Device 2 name: Iris Pro
[LuxRays][19.683] Device 2 type: OPENCL_GPU
[LuxRays][19.683] Device 2 compute units: 40
[LuxRays][19.683] Device 2 preferred float vector width: 1
[LuxRays][19.683] Device 2 max allocable memory: 1536MBytes
[LuxRays][19.683] Device 2 max allocable memory block size: 384MBytes
[LuxRays][19.683] Device 2 has out of core memory support: 0
[LuxRays][19.683] Device 3 name: GeForce GT 750M
[LuxRays][19.683] Device 3 type: OPENCL_GPU
[LuxRays][19.683] Device 3 compute units: 2
[LuxRays][19.683] Device 3 preferred float vector width: 1
[LuxRays][19.683] Device 3 max allocable memory: 2048MBytes
[LuxRays][19.683] Device 3 max allocable memory block size: 512MBytes
[LuxRays][19.683] Device 3 has out of core memory support: 0
[LuxRays][19.683] Device 4 name: GeForce GT 750M
[LuxRays][19.683] Device 4 type: CUDA_GPU
[LuxRays][19.683] Device 4 compute units: 192
[LuxRays][19.683] Device 4 preferred float vector width: 1
[LuxRays][19.683] Device 4 max allocable memory: 2047MBytes
[LuxRays][19.683] Device 4 max allocable memory block size: 17592186044415MBytes
[LuxRays][19.683] Device 4 has out of core memory support: 1
Post by Dade » Fri May 29, 2020 10:20 am
Ok, so it looks like everything is ok, I will merge the branch than we will have to update Azure build process to build only one type of executable.
Post by Dade » Fri May 29, 2020 10:24 am
Done.
