Where is this error ?
Unified executable (for CPU-only, OpenCL and CUDA)
Re: Unified executable (for CPU-only, OpenCL and CUDA)
There are no cuda libs in the package created by LuxCore Azure ..
portfolio http://q3de.com/
MB Pro i7 2.3Ghz, IrisPro 1.5GB, GTX750m 2GB - High Sierra
Xeon X5650@4Ghz, RX 5700 - BigSur / Catalina / High Sierra, Windows 10, Ubuntu 18.04
Hi, testing latest Luxcore 2.4 on Linux and it work fine with but view port render compile forever.
I got following errors:
does not exist.
I have Cuda toolkit 10.2, GTX 760, driver 440.82
Cheers, mib
Export took 0.0 s
[LuxCore][28007.456] Film resolution: 529x298
[SDL][28007.457] Film output definition: RGB_IMAGEPIPELINE [image.png]
[SDL][28007.457] Image pipeline: film.imagepipelines.000
[SDL][28007.457] Image pipeline step 0: NOP
[SDL][28007.457] Image pipeline step 1: TONEMAP_LINEAR
[SDL][28007.457] Film output definition: RGB_IMAGEPIPELINE [RGB_IMAGEPIPELINE_0.png]
[LuxRays][28007.457] OpenCL support: enabled
[LuxRays][28007.457] OpenCL Platform 0: NVIDIA CUDA
[LuxRays][28007.457] CUDA support: enabled
[LuxRays][28007.457] CUDA support: available
[LuxRays][28007.457] CUDA driver version: 10.20
[LuxRays][28007.457] CUDA device count: 1
[LuxRays][28007.457] Device 0 name: Native
[LuxRays][28007.457] Device 0 type: NATIVE_THREAD
[LuxRays][28007.457] Device 0 compute units: 1
[LuxRays][28007.457] Device 0 preferred float vector width: 4
[LuxRays][28007.457] Device 0 max allocable memory: 17592186044415MBytes
[LuxRays][28007.457] Device 0 max allocable memory block size: 17592186044415MBytes
[LuxRays][28007.457] Device 0 has out of core memory support: 0
[LuxRays][28007.457] Device 1 name: GeForce GTX 760
[LuxRays][28007.457] Device 1 type: OPENCL_GPU
[LuxRays][28007.457] Device 1 compute units: 6
[LuxRays][28007.457] Device 1 preferred float vector width: 1
[LuxRays][28007.458] Device 1 max allocable memory: 4029MBytes
[LuxRays][28007.458] Device 1 max allocable memory block size: 1007MBytes
[LuxRays][28007.458] Device 1 has out of core memory support: 0
[LuxRays][28007.458] Device 2 name: GeForce GTX 760
[LuxRays][28007.458] Device 2 type: CUDA_GPU
[LuxRays][28007.458] Device 2 compute units: 192
[LuxRays][28007.458] Device 2 preferred float vector width: 1
[LuxRays][28007.458] Device 2 max allocable memory: 4029MBytes
[LuxRays][28007.458] Device 2 max allocable memory block size: 17592186044415MBytes
[LuxRays][28007.458] Device 2 has out of core memory support: 1
[LuxRays][28007.458] Creating 1 intersection device(s)
[LuxRays][28007.458] Allocating intersection device 0: GeForce GTX 760 (Type = CUDA_GPU)
ERROR: CUDA driver API error CUDA_ERROR_UNKNOWN (code: 999, file:/home/vsts/work/1/s/LinuxCompile/LuxCore/src/luxrays/devices/cudadevice.cpp, line: 136): unknown error
File "/home/pepo/blender-2.82-linux64/2.82/scripts/addons/BlendLuxCore/engine/viewport.py", line 51, in view_update
engine.session = engine.exporter.create_session(depsgraph, context, engine=engine)
File "/home/pepo/blender-2.82-linux64/2.82/scripts/addons/BlendLuxCore/export/__init__.py", line 247, in create_session
return pyluxcore.RenderSession(renderconfig)
RuntimeError: CUDA driver API error CUDA_ERROR_UNKNOWN (code: 999, file:/home/vsts/work/1/s/LinuxCompile/LuxCore/src/luxrays/devices/cudadevice.cpp, line: 136): unknown error
[SDL][28007.461] Camera type: perspective
[SDL][28007.461] Camera position: Point[0, 0, 0]
[SDL][28007.461] Camera target: Point[0, 0, 0]
[SDL][28007.461] Camera clipping plane disabled
[LuxCore][28007.461] Configuration:
[LuxCore][28007.461] renderengine.type = "RTPATHOCL"
[LuxCore][28007.461] sampler.type = "TILEPATHSAMPLER"
[LuxCore][28007.461] scene.epsilon.min = 9.9999997473787516e-06
[LuxCore][28007.461] scene.epsilon.max = 0.10000000149011612
[LuxCore][28007.461] File Name Resolver Configuration:
Cheers, mib
Viewport rendering on Linux is working fine here however I'm using CUDA 10.1 but 10.2 shouldn't be a problem. The error looks quite strange and like a driver internal error. Does Cycles with CUDA works on the same PC ?
@Dade, yes I compile Blender on this system and have to compile the Cuda kernel for my SM_30 card, too.
I will check on my Windows disk on the same system today.
Cheers, mib
EDIT: It work on Windows 10 with 441.87 but it show "Kernel OpenCL compilation need a few minutes, once." or so.
Back to Linux, will try to delete all kernels.
EDIT 2: It work now, delete all kernels and there was a lot of them.
Thanks for watching
Cheers, mib
Thanks for watching
one exe file is great
Many thanks to devs
Get interesting result on test scene
GPU 1min 04 sek
CPU 1min 02 sek
GPU+CPU 47sek
all with PGI on
Win 7 LuxCore (Last buld 01 june)
GPU GTX1070
CPU E5 2650v2
Many thanks to devs
GPU 1min 04 sek
CPU 1min 02 sek
GPU+CPU 47sek
all with PGI on
GPU GTX1070
CPU E5 2650v2
@Dade, how does this work on Linux? Isn't it necessary to distribute the Nvidia nvrtc and nvrtc-builtins DLLs as for the other platforms?
I have to check but I assume the answer is yes (they are not included with the drivers).
Sorry for asking this silly question but where can you find CUDA support in luxcore 2.4 beta?
I am unable to know if via GPU it used openCL or CUDA?
It should be in BlendLuxCore addon preferences
