LuxCoreRender Project wants you!
Re: LuxCoreRender Project wants you!
Post by Dade » Tue Dec 03, 2019 4:41 pm
Moved the posts related to MacOS compilation on a dedicated thread: viewtopic.php?f=5&t=1589
u3dreal
Post by u3dreal » Tue Dec 03, 2019 4:43 pm
Opensubdiv seems to compile fine ... you mean i could miss the opensudiv include and lib ??
they are in Lux_build/lib so maybe ... how can it be the linker misses ./lib for linking ??
so maybe add a -L/Users/drquader/Documents/Github/Lux_build/lib ??
[ 15%] Built target luxrays
[ 22%] Built target slg-film
[ 49%] Built target slg-kernels
[ 52%] Built target openvdb
[ 56%] Built target opensubdiv
[ 85%] Built target slg-core
[ 86%] Built target bcd
[ 87%] Built target luxcore
[ 88%] Built target pyluxcore
[ 88%] Generating ../../generated/pyluxcoretools/pyluxcoremenu/__init__.py
[ 88%] Generating ../../generated/pyluxcoretools/pyluxcoremenu/cmd.py
[ 88%] Generating ../../generated/pyluxcoretools/utils/__init__.py
[ 88%] Generating ../../generated/pyluxcoretools/utils/args.py
[ 94%] Built target pyluxcoretools_copy_dir
[ 94%] Linking CXX executable ../../luxcoreconsole
portfolio http://q3de.com/
Xeon X5650@4Ghz, RX 5700 - BigSur / Catalina / High Sierra, Windows 10, Ubuntu 18.04
Post by Dade » Tue Dec 03, 2019 4:46 pm
Check my answer in viewtopic.php?f=5&t=1589 thread.
Post by Dade » Wed Apr 22, 2020 12:40 pm
It would help me a lot to have a Linux platform maintainer so I don't have to worried about maintaining Linux binaries too. Any help is welcome.
klayman
Post by klayman » Wed Apr 22, 2020 2:13 pm
I'm not the best candidate for this, but I want to help the LuxCoreRender project. How much time would it require? Is there anything that could be automated? I'm on Fedora Linux.
Sorry for the abandoned site design update, BTW. Perhaps, I should continue on it instead. I had absolutely no spare time last months.
Post by Dade » Wed Apr 22, 2020 2:54 pm
It occasionally takes some time to update some external library binary. We have now the slightly more complex problem of supporting CUDA builds on Azure for Linux. Usually, it takes no time at all because there is nothing changed in the building process.
The Linux maintainer task is mostly to maintain https://github.com/LuxCoreRender/LinuxCompile and https://github.com/LuxCoreRender/LinuxCompileDeps repositories. You should probably check the repositories to have an idea of what the task involves.
