Thin-film Interference
Posted: Mon May 11, 2020 5:39 pm
I have added support for thin-film interference to the following materials:
  • Glass
  • Arch. glass
  • Rough glass
  • Disney
It can be used for oil slicks, soap bubbles, oxid layers on heated metal, car paint, anti-reflective coatings, beetle carapace etc.
The resulting colors depend on the thickness of the film, the refractive index of the film, and the angle between surface and viewer.
BlendLuxCore
In the Blender addon, the "glass" and "disney" nodes now have a "Thin Film Coating" checkbox.
If enabled, you can specify the thin film thickness (in nanometers) and the IOR of the coating material with two new sockets.
On the disney node, there is an additional "Film Amount" socket so you can mix in more or less of the film effect.
LuxCore SDL
The textures to control the film appearance are defined with the properties
scene.materials.<material name>.filmthickness = 300  # in nanometers
scene.materials.<material name>.filmior = 1.5
The disney material has the additional property
scene.materials.<material name>.filmamount = 1
which is the linear interpolation factor between no film and film.
Re: Thin Film Interference
Posted: Mon May 11, 2020 6:44 pm
by u3dreal
Looks really awesome !!! :o
Posted: Mon May 11, 2020 7:22 pm
Yup, this is a fantastic addition. :D
Re: Thin-film Interference
Posted: Tue May 12, 2020 9:39 am
by JoeDDD
B.Y.O.B. wrote: Mon May 11, 2020 5:39 pm I have added support for thin-film interference to the following materials:
  • Glass
  • Arch. glass
  • Rough glass
  • Disney
Would it be possible to add film option also to anisotropic metal shader? Because the disney anisotropic works kinda weird and has less options.
Great addition btw!
Posted: Tue May 12, 2020 12:47 pm
by TAO
Weldone.
Which revision could I use so I can add thin-film interference to MaxToLux?
Posted: Tue May 12, 2020 12:50 pm
You will need the latest daily build of LuxCore.
Posted: Fri May 15, 2020 4:01 pm
by Fox
Very cool feature, thank you.
I tested this out on my camera scene:
