Hello Together,
I heard that in an .exr-File the Luminance in cd/m^2 is stored.
Here: viewtopic.php?f=4&t=1601&p=20519&hilit= ... nce#p20519 is said, that if I turn off the Tonemapper the values are stored in cd/m^2. In my opinion this vaule shouldn't change by changing the focal length of the Camera.
Thanks,
Meinhard
Settings to get the luminance in an .exr file
Re: Settings to get the luminance in an .exr file
It depends how the image pipeline is set: the EXR is saved at the end of image pipeline execution so you need to create an image pipeline without any kind of tone mapping, gamma correction, etc. or they will mess the result.Meinhard wrote: ↑Thu Apr 16, 2020 3:21 pm I heard that in an .exr-File the Luminance in cd/m^2 is stored.
In LuxCore, you can have multiple image pipelines so you can have the one mapping, gamma correction, etc. in one (for displaying) and the untouched luminance values in another. Are you using directly LuxCore API or our Blender plugin ?
Thanks for the fast reply.
Im using the Blender Plugin. ´The file im working with is attached. I've deactivated the tone mapping and set gamma to 1, view Transform to raw and exposure to 0.
Thanks
Thanks
