Can luxcore support OSL?
How can I make luxcore support the OSL language? Include GPU rendering
Re: Can luxcore support OSL?
I doubt it will ever happen because OSL isn't really suited for GPU support. As far as I know, even Cycles support OSL only on CPUs.
Octane supports it on gpus... maybe arnold too
Because I want luxcore to support materialx material library, but this material library is implemented in OSL language, so I have this requirement
So I want to know how much work it will take if luxcore supports OSL (including GPU rendering)
Brecht, developer of Cycles, once said this:
https://www.blenderdiplom.com/en/interviews/400-interview-brecht-van-lommel-on-cycles.html wrote:The main issue is to get OSL working on the GPU. It's almost as much work as building Cycles itself. It's not easy to do so we need more people to help us.
B.Y.O.B. wrote: ↑Wed Apr 15, 2020 12:41 pm Brecht, developer of Cycles, once said this:https://www.blenderdiplom.com/en/interviews/400-interview-brecht-van-lommel-on-cycles.html wrote:The main issue is to get OSL working on the GPU. It's almost as much work as building Cycles itself. It's not easy to do so we need more people to help us.
Thank you for your reply
