Windows Build FAILED
Re: Windows Build FAILED
Ah, didn't know it was deprecated. I'll use the replacement.
Ok, CUDA devices now show up in BlendLuxCore and the device string is now the correct length.
However, I'm getting the following error:
Do I have to install anything besides the Nvidia driver to make it work on Windows 10?
[LuxRays][12.891] [BVHKernel] Compiling kernels
[LuxRays][12.891] [BVHKernel] CUDA program compilation error:
nvrtc: error: failed to open nvrtc-builtins64_101.dll.
Make sure that nvrtc-builtins64_101.dll is installed correctly.
File "C:\Users\Simon\AppData\Roaming\Blender Foundation\Blender\2.82\scripts\addons\BlendLuxCore_git\engine\base.py", line 83, in render_final
final.render(self, depsgraph)
File "C:\Users\Simon\AppData\Roaming\Blender Foundation\Blender\2.82\scripts\addons\BlendLuxCore_git\engine\final.py", line 49, in render
_render_layer(engine, depsgraph, statistics, layer)
File "C:\Users\Simon\AppData\Roaming\Blender Foundation\Blender\2.82\scripts\addons\BlendLuxCore_git\engine\final.py", line 73, in _render_layer
engine.session.Start()
RuntimeError: BVHKernel CUDA program compilation error
The DLL is included in CUDA SDK however I was under the impression Acasta69 was including the DLL in our archive tooB.Y.O.B. wrote: Sun Apr 26, 2020 9:57 pm Do I have to install anything besides the Nvidia driver to make it work on Windows 10?
I have these binaries in the addon's bin folder:
- Capture.PNG (9.62 KiB) Viewed 7000 times
I assume Nvidia driver doesn't look in that directory. The builtin dll is likely to be loaded by the driver.
On my desktop PC LuxcoreUI works correctly with the two DLLs in the same folder as the LuxcoreUI executable, and stops working when I remove them.Dade wrote: Sun Apr 26, 2020 11:57 pm I assume Nvidia driver doesn't look in that directory. The builtin dll is likely to be loaded by the driver.
I assumed the same was true for pyluxcore, but it stopped with the "wrong length" error for the device selection string, and probably the DLLs are search for later.
At the moment I am on my laptop and situation is a bit different. This is what I get in Blender console when trying to render the default cube scene with PathOCL + CUDA:
[LuxRays][1244.016] [Device Quadro M1000M CUDAIntersect] Sample buffer size: 311296Kbytes
File "C:\Users\italcas1\AppData\Roaming\Blender Foundation\Blender\2.82\scripts\addons\BlendLuxCore\engine\base.py", line 83, in render_final
File "C:\Users\italcas1\AppData\Roaming\Blender Foundation\Blender\2.82\scripts\addons\BlendLuxCore\engine\final.py", line 49, in render
File "C:\Users\italcas1\AppData\Roaming\Blender Foundation\Blender\2.82\scripts\addons\BlendLuxCore\engine\final.py", line 73, in _render_layer
RuntimeError: CUDA driver API error CUDA_ERROR_OUT_OF_MEMORY (code: 2, file:D:\a\1\Luxcore\src\luxrays\devices\cudadevice.cpp, line: 440): out of memory
ERROR: CUDA driver API error CUDA_ERROR_OUT_OF_MEMORY (code: 2, file:D:\a\1\Luxcore\src\luxrays\devices\cudadevice.cpp, line: 440): out of memory
I'll do more tests as soon as possible, but I have two-three quite busy days ahead of me, sorry...
P.S. By the way, the cube scene works perfectly on the laptop if I select the openCL device.
Indeed, another quick test on the laptop showed that, if the DLLs are not present at all, the addon is not even loaded.
Restoring them in the addon bin directory made it work.
[LuxRays][30.219] [BVHKernel] Compiling kernels
[LuxRays][30.219] [BVHKernel] CUDA program compilation error:
This is what i get with BlendLuxCoreCuda for Win with the latest builds
I use the Link from kintux a few days ago.
http://www.cngwireless.net/apps/Drivers ... etwork.exe
to download the nvidia cuda sdk and the the compiling worked.
But I think there is a newer SDK Version available. Dont know if that makes a different.
But I ran into the next problem.
I get this error:
self._width, self._height, combined.as_pointer(), False, True)
RuntimeError: clEnqueueWriteBuffer
ERROR: clEnqueueWriteBuffer
[LuxCore][1690.265] [GeForce RTX 2070 OpenCLIntersect] Memory used for hardware image pipeline: 1025390Kbytes
I have two rtx cards and when i select both for cuda rendering i get the error. Also if i choose the one where the monitor is connected.
If I choose only the second one I can render the image.
Viewport rendering works with both selected.
I get this error:
It may be this problem: https://stackoverflow.com/questions/138 ... mory-failsacasta69 wrote: Mon Apr 27, 2020 7:22 am At the moment I am on my laptop and situation is a bit different. This is what I get in Blender console when trying to render the default cube scene with PathOCL + CUDA:Code: Select all
311296Kbytes is a quite big chunk of memory and you may hit a this Windows specfic limit on the laptop
