Windows Build FAILED
Post by kintuX » Wed Mar 25, 2020 3:52 pm
W10, Latest commit 04298f479, gives:
--- FATAL ERROR RUNNING CMAKE ---
Build FAILED.
       "C:\luxcorerender\WindowsCompile\Build_CMake\LuxCore\LuxRays.sln" (default target) (1) ->
       "C:\luxcorerender\WindowsCompile\Build_CMake\LuxCore\src\luxrays\luxrays.vcxproj" (default target) (8) ->
       (ClCompile target) ->
         c:\luxcorerender\luxcore\src\luxrays\devices\ocldevice.cpp(244): error C2664: 'cl_int cl::Kernel::setArg(cl_ui
       nt,size_t,void *)': cannot convert argument 3 from 'const void *' to 'void *' [C:\luxcorerender\WindowsCompile\B
       uild_CMake\LuxCore\src\luxrays\luxrays.vcxproj]
Re: Windows Build FAILED
Post by Dade » Wed Mar 25, 2020 4:58 pm
Build FAILED.
You may have a old/wrong/broken version of https://www.khronos.org/registry/OpenCL/api/2.1/cl.hpp installed on your system. It is working fine with the linked cl.hpp on Azure for Windows.
acasta69
Post by acasta69 » Wed Mar 25, 2020 5:01 pm
Most probably you need to replace file cl.hpp in your OpenCL SDK distribution with a more recent version.
You can download it from here:
Edit: Ooops, I didn't notice Dade answered in the meantime...
Windows 10 64 bits, i7-4770 3.4 GHz, RAM 16 GB, GTX 970 4GB v382.05
Post by kintuX » Wed Mar 25, 2020 5:37 pm
Yup, that was it! Got it back on track and is building fine :D
Thank you both!
BTW - What is the "giveaway"? How can I recognize the culprit in the future?
Post by Dade » Wed Mar 25, 2020 5:55 pm
I doubt we will ever change OpenCL version (i.e. v1.2) so you should be fine with that file for any foreseeable future.
Post by kintuX » Fri Mar 27, 2020 1:53 am
Yeah, new era commences. ;)
