2-Levels Env. Light Visibility Cache
marcatore
Re: 2-Levels Env. Light Visibility Cache
Post by marcatore » Wed Mar 18, 2020 8:57 pm
you're right.
I've seen another strange thing.
Env Cache OFF
Env Cache 1.0
Is it correct that the bright part (where there is the mouse pointer) is noiser with the Env Cache?
Post by Dade » Wed Mar 18, 2020 10:16 pm
You can reduce that noise by increasing the visibility map resolution but, most of the times, it is not worth doing because, anyway, it should clear that noise pretty fast. As you can see, the cache is more effective in penumbra/shadow area.
Post by Dade » Wed Mar 18, 2020 10:17 pm
B.Y.O.B. wrote:
Wed Mar 18, 2020 8:43 pm
Most noise in this scene comes from indirect light, which is not accelerated by env. light cache (use PhotonGI instead).
This is the result when I set max bounces to 1 (only render direct light):
Like day and night :mrgreen:
Post by Sharlybg » Thu Mar 19, 2020 9:12 am
This is my tests
Strangely the best result come from Env.cache Quality 0.5/ . Quality 1.0 give more indirect noise.
