Network Render
acasta69
Re: Network Render
Post by acasta69 » Wed Feb 19, 2020 6:13 pm
mib2berlin wrote:
Tue Feb 18, 2020 12:51 am
EDIT: Got not exactly the same errors:
C:\Users\pepo\Downloads\blender-2.82-windows64\2.82\scripts\addons\BlendLuxCore\bin>python pyluxcoretools.zip netnodeui
ImportError: numpy.core.multiarray failed to import
ImportError: numpy.core.umath failed to import
  File "C:\Users\pepo\AppData\Local\Programs\Python\Python37\lib\runpy.py", line 193, in _run_module_as_main
    "__main__", mod_spec)
  File "C:\Users\pepo\AppData\Local\Programs\Python\Python37\lib\runpy.py", line 85, in _run_code
    exec(code, run_globals)
  File "pyluxcoretools.zip\__main__.py", line 71, in <module>
  File "pyluxcoretools.zip\pyluxcoretools\pyluxcorenetnode\ui.py", line 144, in main
  File "pyluxcoretools.zip\pyluxcoretools\pyluxcorenetnode\ui.py", line 135, in ui
  File "pyluxcoretools.zip\pyluxcoretools\pyluxcorenetnode\ui.py", line 46, in __init__
  File "pyluxcoretools.zip\pyluxcoretools\pyluxcorenetnode\mainwindow.py", line 196, in setupUi
AttributeError: 'PySide2.QtWidgets.QAction' object has no attribute 'activated'
The error shown in the last line should be solved in the "latest" release being built right now.
Regarding the numpy errors, have you installed numpy on your system?
You can do that with:
pip install numpy
Windows 10 64 bits, i7-4770 3.4 GHz, RAM 16 GB, GTX 970 4GB v382.05
mib2berlin
Re: Network Render
Post by mib2berlin » Mon Feb 24, 2020 7:20 pm
Hi, had some time to test latest luxcore from git and after install numpy the render node is starting on my second Windows system.
Seams fixed now.
Thank you for the help, mib
