sudo pip3 install --install-option="--jobs=4" PySide
ERROR: Command errored out with exit status 1:
command: /usr/bin/python3 -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-nw01ambb/PySide/setup.py'"'"'; __file__='"'"'/tmp/pip-install-nw01ambb/PySide/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' egg_info --egg-base /tmp/pip-install-nw01ambb/PySide/pip-egg-info
cwd: /tmp/pip-install-nw01ambb/PySide/
Complete output (1 lines):
only these python versions are supported: [(2, 6), (2, 7), (3, 2), (3, 3), (3, 4)]
ERROR: Command errored out with exit status 1: python setup.py egg_info Check the logs for full command output.Tested with LuxCore 2.2 and latest Git build.
Would be very grateful for help.
Cheers, mib
EDIT: It seams forum search is broken
