HOWTO - compile on OSX 2020
Posted: Fri Jan 17, 2020 3:34 pm
Hi i'm about to put together a guide on how to compile LuxCore on macOS operating systems.
This is a start.
Compile LuxCoreRender on OSX 10.13+
Install latest Xcode and Command Line Tools for your OS version.
Install Homebrew
Install brew stuff and python3
Compile Dependencies
This will leave you with a .tar
Compile LuxCore
Copy tar to LuxCore root and unpack. Just double-click. or
change
to "0" in cmake/PlatformSpecific.cmake
Now do
now copy paste this to a text file ... like "pack_lux_osx.sh" and save it.
Do and run it
This should end up with a distributable .dmg.
Have fun and good luck.
This is a start.
Install Homebrew
/usr/bin/ruby -e "$(curl -fsSL https://raw.githubusercontent.com/Homebrew/install/master/install)"
brew install pyenv cmake bison gnu-sed gnu-tar xz libtool autoconf automake
PATH="/usr/local/opt/gnu-sed/libexec/gnubin:$PATH"
PATH="/usr/local/opt/gnu-tar/libexec/gnubin:$PATH"
eval "$(pyenv init -)”.
env PYTHON_CONFIGURE_OPTS="--enable-framework" pyenv install 3.7.4
pyenv global 3.7.4
pip install numpy
pip install pillow
pip install pyside2
pyenv shell 3.7.4
git clone https://github.com/LuxCoreRender/MacOSCompileDeps.git
cd MacOSCompileDeps
./cut_deps_release
Compile LuxCore
git clone https://github.com/LuxCoreRender/LuxCore.git
cd LuxCore
tar xzf MacDistFiles.tar.gz
SET(AZURE 1) # Set 0 when compiled locally and not on azure
Now do
export PATH="/usr/local/opt/bison/bin:/usr/local/bin:$PATH"
DEPS_SOURCE=`pwd`/macos
mkdir build
cd build
cmake -DOSX_DEPENDENCY_ROOT=$DEPS_SOURCE -DCMAKE_BUILD_TYPE=Release ..
make
#!/bin/bash
### packing opencl version
mkdir release_OSX
###luxcoreui bundle
echo "Bundeling OpenCL Version"
cp -R macos/mac_bundle/LuxCore.app release_OSX
cp build/Release/luxcoreui release_OSX/LuxCore.app/Contents/MacOS
cd release_OSX
mkdir -p LuxCore.app/Contents/Resources/libs/
#libomp
cp -f $DEPS_SOURCE/lib/libomp.dylib LuxCore.app/Contents/Resources/libs/libomp.dylib
chmod +w LuxCore.app/Contents/Resources/libs/libomp.dylib
install_name_tool -id @executable_path/../Resources/libs/libomp.dylib LuxCore.app/Contents/Resources/libs/libomp.dylib
#libembree
cp -f $DEPS_SOURCE/lib/libembree3.3.dylib LuxCore.app/Contents/Resources/libs/libembree3.3.dylib
chmod +w LuxCore.app/Contents/Resources/libs/libembree3.3.dylib
install_name_tool -id @executable_path/../Resources/libs/libembree3.3.dylib LuxCore.app/Contents/Resources/libs/libembree3.3.dylib
install_name_tool -change @rpath/libtbb.dylib @executable_path/../Resources/libs/libtbb.dylib LuxCore.app/Contents/Resources/libs/libembree3.3.dylib
install_name_tool -change @rpath/libtbbmalloc.dylib @executable_path/../Resources/libs/libtbbmalloc.dylib LuxCore.app/Contents/Resources/libs/libembree3.3.dylib
#libOpenImageDenoise
cp -f $DEPS_SOURCE/lib/libOpenImageDenoise.1.0.0.dylib LuxCore.app/Contents/Resources/libs/libOpenImageDenoise.1.0.0.dylib
chmod +w LuxCore.app/Contents/Resources/libs/libOpenImageDenoise.1.0.0.dylib
install_name_tool -id @executable_path/../Resources/libs/libOpenImageDenoise.1.0.0.dylib LuxCore.app/Contents/Resources/libs/libOpenImageDenoise.1.0.0.dylib
install_name_tool -change @rpath/libtbb.dylib @executable_path/../Resources/libs/libtbb.dylib LuxCore.app/Contents/Resources/libs/libOpenImageDenoise.1.0.0.dylib
install_name_tool -change @rpath/libtbbmalloc.dylib @executable_path/../Resources/libs/libtbbmalloc.dylib LuxCore.app/Contents/Resources/libs/libOpenImageDenoise.1.0.0.dylib
#libtbb
cp -f $DEPS_SOURCE/lib/libtbb.dylib LuxCore.app/Contents/Resources/libs/libtbb.dylib
chmod +w LuxCore.app/Contents/Resources/libs/libtbb.dylib
install_name_tool -id @executable_path/../Resources/libs/libtbb.dylib LuxCore.app/Contents/Resources/libs/libtbb.dylib
#libtiff
cp -f $DEPS_SOURCE/lib/libtiff.5.dylib LuxCore.app/Contents/Resources/libs/libtiff.5.dylib
chmod +w LuxCore.app/Contents/Resources/libs/libtiff.5.dylib
install_name_tool -id @executable_path/../Resources/libs/libtiff.5.dylib LuxCore.app/Contents/Resources/libs/libtiff.5.dylib
#libOpenImageIO
cp -f $DEPS_SOURCE/lib/libOpenImageIO.1.8.dylib LuxCore.app/Contents/Resources/libs/libOpenImageIO.1.8.dylib
chmod +w LuxCore.app/Contents/Resources/libs/libOpenImageIO.1.8.dylib
install_name_tool -id @executable_path/../Resources/libs/libOpenImageIO.1.8.dylib LuxCore.app/Contents/Resources/libs/libOpenImageIO.1.8.dylib
install_name_tool -change @rpath/libtiff.5.dylib @executable_path/../Resources/libs/libtiff.5.dylib LuxCore.app/Contents/Resources/libs/libOpenImageIO.1.8.dylib
#libtbbmalloc
cp -f $DEPS_SOURCE/lib/libtbbmalloc.dylib LuxCore.app/Contents/Resources/libs/libtbbmalloc.dylib
chmod +w LuxCore.app/Contents/Resources/libs/libtbbmalloc.dylib
install_name_tool -id @executable_path/../Resources/libs/libtbbmalloc.dylib LuxCore.app/Contents/Resources/libs/libtbbmalloc.dylib
#luxcoreui
install_name_tool -change @rpath/libomp.dylib @executable_path/../Resources/libs/libomp.dylib LuxCore.app/Contents/MacOS/luxcoreui
install_name_tool -change @rpath/libembree3.3.dylib @executable_path/../Resources/libs/libembree3.3.dylib LuxCore.app/Contents/MacOS/luxcoreui
install_name_tool -change @rpath/libtbb.dylib @executable_path/../Resources/libs/libtbb.dylib LuxCore.app/Contents/MacOS/luxcoreui
install_name_tool -change @rpath/libOpenImageIO.1.8.dylib @executable_path/../Resources/libs/libOpenImageIO.1.8.dylib LuxCore.app/Contents/MacOS/luxcoreui
install_name_tool -change @rpath/libtbbmalloc.dylib @executable_path/../Resources/libs/libtbbmalloc.dylib LuxCore.app/Contents/MacOS/luxcoreui
install_name_tool -change @rpath/libtiff.5.dylib @executable_path/../Resources/libs/libtiff.5.dylib LuxCore.app/Contents/MacOS/luxcoreui
install_name_tool -change @rpath/libOpenImageDenoise.0.dylib @executable_path/../Resources/libs/libOpenImageDenoise.1.0.0.dylib LuxCore.app/Contents/MacOS/luxcoreui
echo "LuxCoreUi installed"
###luxcoreconsole
cp ../build/Release/luxcoreconsole LuxCore.app/Contents/MacOS
#luxcoreconsole
install_name_tool -change @rpath/libomp.dylib @executable_path/../Resources/libs/libomp.dylib ./LuxCore.app/Contents/MacOS/luxcoreconsole
install_name_tool -change @rpath/libembree3.3.dylib @executable_path/../Resources/libs/libembree3.3.dylib ./LuxCore.app/Contents/MacOS/luxcoreconsole
install_name_tool -change @rpath/libtbb.dylib @executable_path/../Resources/libs/libtbb.dylib ./LuxCore.app/Contents/MacOS/luxcoreconsole
install_name_tool -change @rpath/libOpenImageIO.1.8.dylib @executable_path/../Resources/libs/libOpenImageIO.1.8.dylib ./LuxCore.app/Contents/MacOS/luxcoreconsole
install_name_tool -change @rpath/libtbbmalloc.dylib @executable_path/../Resources/libs/libtbbmalloc.dylib ./LuxCore.app/Contents/MacOS/luxcoreconsole
install_name_tool -change @rpath/libtiff.5.dylib @executable_path/../Resources/libs/libtiff.5.dylib ./LuxCore.app/Contents/MacOS/luxcoreconsole
install_name_tool -change @rpath/libOpenImageDenoise.0.dylib @executable_path/../Resources/libs/libOpenImageDenoise.1.0.0.dylib ./LuxCore.app/Contents/MacOS/luxcoreconsole
echo "LuxCoreConsole installed"
### pyluxcore.so
mkdir pyluxcore
cp ../build/lib/Release/pyluxcore.so pyluxcore
cp ../build/lib/pyluxcoretools.zip pyluxcore
cd pyluxcore
#libomp
cp -f $DEPS_SOURCE/lib/libomp.dylib ./libomp.dylib
chmod +w ./libomp.dylib
install_name_tool -id @loader_path/libomp.dylib ./libomp.dylib
#libembree
cp -f $DEPS_SOURCE/lib/libembree3.3.dylib ./libembree3.3.dylib
chmod +w ./libembree3.3.dylib
install_name_tool -id @loader_path/libembree3.3.dylib ./libembree3.3.dylib
install_name_tool -change @rpath/libtbb.dylib @loader_path/libtbb.dylib ./libembree3.3.dylib
install_name_tool -change @rpath/libtbbmalloc.dylib @loader_path/libtbbmalloc.dylib ./libembree3.3.dylib
#libtbb
cp -f $DEPS_SOURCE/lib/libtbb.dylib ./libtbb.dylib
chmod +w ./libtbb.dylib
install_name_tool -id @loader_path/libtbb.dylib ./libtbb.dylib
#libtiff
cp -f $DEPS_SOURCE/lib/libtiff.5.dylib ./libtiff.5.dylib
chmod +w ./libtiff.5.dylib
install_name_tool -id @loader_path/libtiff.5.dylib ./libtiff.5.dylib
#libOpenImageIO
cp -f $DEPS_SOURCE/lib/libOpenImageIO.1.8.dylib ./libOpenImageIO.1.8.dylib
chmod +w ./libOpenImageIO.1.8.dylib
install_name_tool -id @loader_path/libOpenImageIO.1.8.dylib ./libOpenImageIO.1.8.dylib
install_name_tool -change @rpath/libtiff.5.dylib @loader_path/libtiff.5.dylib ./libOpenImageIO.1.8.dylib
#libtbbmalloc
cp -f $DEPS_SOURCE/lib/libtbbmalloc.dylib ./libtbbmalloc.dylib
chmod +w ./libtbbmalloc.dylib
install_name_tool -id @loader_path/libtbbmalloc.dylib ./libtbbmalloc.dylib
cp -f $DEPS_SOURCE/lib/libOpenImageDenoise.1.0.0.dylib ./libOpenImageDenoise.1.0.0.dylib
chmod +w ./libOpenImageDenoise.1.0.0.dylib
install_name_tool -id @loader_path/libOpenImageDenoise.1.0.0.dylib ./libOpenImageDenoise.1.0.0.dylib
install_name_tool -change @rpath/libtbb.dylib @loader_path/libtbb.dylib ./libOpenImageDenoise.1.0.0.dylib
install_name_tool -change @rpath/libtbbmalloc.dylib @loader_path/libtbbmalloc.dylib ./libOpenImageDenoise.1.0.0.dylib
#pyluxcore.so
install_name_tool -change @rpath/libomp.dylib @loader_path/libomp.dylib pyluxcore.so
install_name_tool -change @rpath/libembree3.3.dylib @loader_path/libembree3.3.dylib pyluxcore.so
install_name_tool -change @rpath/libtbb.dylib @loader_path/libtbb.dylib pyluxcore.so
install_name_tool -change @rpath/libtiff.5.dylib @loader_path/libtiff.5.dylib pyluxcore.so
install_name_tool -change @rpath/libOpenImageIO.1.8.dylib @loader_path/libOpenImageIO.1.8.dylib pyluxcore.so
install_name_tool -change @rpath/libtbbmalloc.dylib @loader_path/libtbbmalloc.dylib pyluxcore.so
install_name_tool -change @rpath/libOpenImageDenoise.0.dylib @loader_path/libOpenImagedenoise.1.0.0.dylib pyluxcore.so
echo "PyLuxCore installed"
### denoise
#denoise
cp ../../macos/bin/denoise .
chmod +w ./denoise
install_name_tool -id @executable_path/denoise ./denoise
install_name_tool -change @rpath/libOpenImageDenoise.0.dylib @executable_path/libOpenImageDenoise.1.0.0.dylib denoise
install_name_tool -change @rpath/libOpenImageDenoise.1.0.0.dylib @executable_path/libOpenImageDenoise.1.0.0.dylib denoise
install_name_tool -change @rpath/libtbb.dylib @executable_path/libtbb.dylib denoise
install_name_tool -change @rpath/libtbbmalloc.dylib @executable_path/libtbbmalloc.dylib denoise
echo "Denoise installed"
cd ../..
# Set up correct names for release version and SDK
if [[ -z "$VERSION_STRING" ]] ; then
VERSION_STRING=latest
fi
### creating opencl DMG
echo "Creating OpenCL Version DMG ..."
hdiutil create luxcorerender-$VERSION_STRING-mac64$SDK_BUILD.dmg -volname "LuxCoreRender-$VERSION_STRING" -fs HFS+ -srcfolder release_OSX/
echo "Done !"
chmod +x pack_lux_osx.sh
./pack_lux_osx.sh
