HOWTO - compile on OSX 2020
u3dreal
Post by u3dreal » Fri Jan 17, 2020 3:34 pm
Hi i'm about to put together a guide on how to compile LuxCore on macOS operating systems.
This is a start.
Compile LuxCoreRender on OSX 10.13+
Install latest Xcode and Command Line Tools for your OS version.
Install Homebrew
/usr/bin/ruby -e "$(curl -fsSL https://raw.githubusercontent.com/Homebrew/install/master/install)"
Install brew stuff and python3
brew install pyenv cmake bison
eval "$(pyenv init -)”.
env PYTHON_CONFIGURE_OPTS="--enable-framework" pyenv install 3.7.4
pyenv global 3.7.4
pip install numpy
pip install pillow
pip install pyside2
Compile Dependencies
pyenv shell 3.7.4
git clone https://github.com/LuxCoreRender/MacOSCompileDeps.git
cd MacOSCompileDeps
./cut_deps_release
This will leave you with a .tar
Compile LuxCore
git clone https://github.com/LuxCoreRender/LuxCore.git
cd LuxCore
Copy tar to LuxCore root and unpack. Just double-click. or
tar xzf MacDistFiles.tar.gz
change
SET(AZURE 1) # Set 0 when compiled locally and not on azure
to "0" in cmake/PlatformSpecific.cmake
Now do
export PATH="/usr/local/opt/bison/bin:/usr/local/bin:$PATH"
DEPS_SOURCE=`pwd`/macos
mkdir build
cd  build
cmake -DOSX_DEPENDENCY_ROOT=$DEPS_SOURCE -DCMAKE_BUILD_TYPE=Release ..
make
now copy paste this to a text file ... like "pack_lux_osx.sh" and save it.
#!/bin/bash
### packing opencl version
mkdir release_OSX
###luxcoreui bundle
echo "Bundeling OpenCL Version"
cp -R macos/mac_bundle/LuxCore.app release_OSX
cp build/Release/luxcoreui release_OSX/LuxCore.app/Contents/MacOS
cd release_OSX
mkdir -p LuxCore.app/Contents/Resources/libs/
#libomp
cp -f $DEPS_SOURCE/lib/libomp.dylib LuxCore.app/Contents/Resources/libs/libomp.dylib
chmod +w LuxCore.app/Contents/Resources/libs/libomp.dylib
install_name_tool -id @executable_path/../Resources/libs/libomp.dylib LuxCore.app/Contents/Resources/libs/libomp.dylib
#libembree
cp -f $DEPS_SOURCE/lib/libembree3.3.dylib LuxCore.app/Contents/Resources/libs/libembree3.3.dylib
chmod +w LuxCore.app/Contents/Resources/libs/libembree3.3.dylib
install_name_tool -id @executable_path/../Resources/libs/libembree3.3.dylib LuxCore.app/Contents/Resources/libs/libembree3.3.dylib
install_name_tool -change @rpath/libtbb.dylib @executable_path/../Resources/libs/libtbb.dylib LuxCore.app/Contents/Resources/libs/libembree3.3.dylib
install_name_tool -change @rpath/libtbbmalloc.dylib @executable_path/../Resources/libs/libtbbmalloc.dylib LuxCore.app/Contents/Resources/libs/libembree3.3.dylib
#libOpenImageDenoise
cp -f $DEPS_SOURCE/lib/libOpenImageDenoise.1.0.0.dylib LuxCore.app/Contents/Resources/libs/libOpenImageDenoise.1.0.0.dylib
chmod +w LuxCore.app/Contents/Resources/libs/libOpenImageDenoise.1.0.0.dylib
install_name_tool -id @executable_path/../Resources/libs/libOpenImageDenoise.1.0.0.dylib LuxCore.app/Contents/Resources/libs/libOpenImageDenoise.1.0.0.dylib
install_name_tool -change @rpath/libtbb.dylib @executable_path/../Resources/libs/libtbb.dylib LuxCore.app/Contents/Resources/libs/libOpenImageDenoise.1.0.0.dylib
install_name_tool -change @rpath/libtbbmalloc.dylib @executable_path/../Resources/libs/libtbbmalloc.dylib LuxCore.app/Contents/Resources/libs/libOpenImageDenoise.1.0.0.dylib
#libtbb
cp -f $DEPS_SOURCE/lib/libtbb.dylib LuxCore.app/Contents/Resources/libs/libtbb.dylib
chmod +w LuxCore.app/Contents/Resources/libs/libtbb.dylib
install_name_tool -id @executable_path/../Resources/libs/libtbb.dylib LuxCore.app/Contents/Resources/libs/libtbb.dylib
#libtiff
cp -f $DEPS_SOURCE/lib/libtiff.5.dylib LuxCore.app/Contents/Resources/libs/libtiff.5.dylib
chmod +w LuxCore.app/Contents/Resources/libs/libtiff.5.dylib
install_name_tool -id @executable_path/../Resources/libs/libtiff.5.dylib LuxCore.app/Contents/Resources/libs/libtiff.5.dylib
#libOpenImageIO
cp -f $DEPS_SOURCE/lib/libOpenImageIO.1.8.dylib LuxCore.app/Contents/Resources/libs/libOpenImageIO.1.8.dylib
chmod +w LuxCore.app/Contents/Resources/libs/libOpenImageIO.1.8.dylib
install_name_tool -id @executable_path/../Resources/libs/libOpenImageIO.1.8.dylib LuxCore.app/Contents/Resources/libs/libOpenImageIO.1.8.dylib
install_name_tool -change @rpath/libtiff.5.dylib @executable_path/../Resources/libs/libtiff.5.dylib LuxCore.app/Contents/Resources/libs/libOpenImageIO.1.8.dylib
#libtbbmalloc
cp -f $DEPS_SOURCE/lib/libtbbmalloc.dylib LuxCore.app/Contents/Resources/libs/libtbbmalloc.dylib
chmod +w LuxCore.app/Contents/Resources/libs/libtbbmalloc.dylib
install_name_tool -id @executable_path/../Resources/libs/libtbbmalloc.dylib LuxCore.app/Contents/Resources/libs/libtbbmalloc.dylib
#luxcoreui
install_name_tool -change @rpath/libomp.dylib @executable_path/../Resources/libs/libomp.dylib LuxCore.app/Contents/MacOS/luxcoreui
install_name_tool -change @rpath/libembree3.3.dylib @executable_path/../Resources/libs/libembree3.3.dylib LuxCore.app/Contents/MacOS/luxcoreui
install_name_tool -change @rpath/libtbb.dylib @executable_path/../Resources/libs/libtbb.dylib LuxCore.app/Contents/MacOS/luxcoreui
install_name_tool -change @rpath/libOpenImageIO.1.8.dylib @executable_path/../Resources/libs/libOpenImageIO.1.8.dylib LuxCore.app/Contents/MacOS/luxcoreui
install_name_tool -change @rpath/libtbbmalloc.dylib @executable_path/../Resources/libs/libtbbmalloc.dylib LuxCore.app/Contents/MacOS/luxcoreui
install_name_tool -change @rpath/libtiff.5.dylib @executable_path/../Resources/libs/libtiff.5.dylib LuxCore.app/Contents/MacOS/luxcoreui
install_name_tool -change @rpath/libOpenImageDenoise.0.dylib @executable_path/../Resources/libs/libOpenImageDenoise.1.0.0.dylib LuxCore.app/Contents/MacOS/luxcoreui
echo "LuxCoreUi installed"
###luxcoreconsole
cp ../build/Release/luxcoreconsole LuxCore.app/Contents/MacOS
#luxcoreconsole
install_name_tool -change @rpath/libomp.dylib @executable_path/../Resources/libs/libomp.dylib ./LuxCore.app/Contents/MacOS/luxcoreconsole
install_name_tool -change @rpath/libembree3.3.dylib @executable_path/../Resources/libs/libembree3.3.dylib ./LuxCore.app/Contents/MacOS/luxcoreconsole
install_name_tool -change @rpath/libtbb.dylib @executable_path/../Resources/libs/libtbb.dylib ./LuxCore.app/Contents/MacOS/luxcoreconsole
install_name_tool -change @rpath/libOpenImageIO.1.8.dylib @executable_path/../Resources/libs/libOpenImageIO.1.8.dylib ./LuxCore.app/Contents/MacOS/luxcoreconsole
install_name_tool -change @rpath/libtbbmalloc.dylib @executable_path/../Resources/libs/libtbbmalloc.dylib ./LuxCore.app/Contents/MacOS/luxcoreconsole
install_name_tool -change @rpath/libtiff.5.dylib @executable_path/../Resources/libs/libtiff.5.dylib ./LuxCore.app/Contents/MacOS/luxcoreconsole
install_name_tool -change @rpath/libOpenImageDenoise.0.dylib @executable_path/../Resources/libs/libOpenImageDenoise.1.0.0.dylib ./LuxCore.app/Contents/MacOS/luxcoreconsole
echo "LuxCoreConsole installed"
### pyluxcore.so
mkdir pyluxcore
cp ../build/lib/Release/pyluxcore.so pyluxcore
cp ../build/lib/pyluxcoretools.zip pyluxcore
cd pyluxcore
#libomp
cp -f $DEPS_SOURCE/lib/libomp.dylib ./libomp.dylib
chmod +w ./libomp.dylib
install_name_tool -id @loader_path/libomp.dylib ./libomp.dylib
#libembree
cp -f $DEPS_SOURCE/lib/libembree3.3.dylib ./libembree3.3.dylib
chmod +w ./libembree3.3.dylib
install_name_tool -id @loader_path/libembree3.3.dylib ./libembree3.3.dylib
install_name_tool -change @rpath/libtbb.dylib @loader_path/libtbb.dylib ./libembree3.3.dylib
install_name_tool -change @rpath/libtbbmalloc.dylib @loader_path/libtbbmalloc.dylib ./libembree3.3.dylib
#libtbb
cp -f $DEPS_SOURCE/lib/libtbb.dylib ./libtbb.dylib
chmod +w ./libtbb.dylib
install_name_tool -id @loader_path/libtbb.dylib ./libtbb.dylib
#libtiff
cp -f $DEPS_SOURCE/lib/libtiff.5.dylib ./libtiff.5.dylib
chmod +w ./libtiff.5.dylib
install_name_tool -id @loader_path/libtiff.5.dylib ./libtiff.5.dylib
#libOpenImageIO
cp -f $DEPS_SOURCE/lib/libOpenImageIO.1.8.dylib ./libOpenImageIO.1.8.dylib
chmod +w ./libOpenImageIO.1.8.dylib
install_name_tool -id @loader_path/libOpenImageIO.1.8.dylib ./libOpenImageIO.1.8.dylib
install_name_tool -change @rpath/libtiff.5.dylib @loader_path/libtiff.5.dylib ./libOpenImageIO.1.8.dylib
#libtbbmalloc
cp -f $DEPS_SOURCE/lib/libtbbmalloc.dylib ./libtbbmalloc.dylib
chmod +w ./libtbbmalloc.dylib
install_name_tool -id @loader_path/libtbbmalloc.dylib ./libtbbmalloc.dylib
cp -f $DEPS_SOURCE/lib/libOpenImageDenoise.1.0.0.dylib ./libOpenImageDenoise.1.0.0.dylib
chmod +w ./libOpenImageDenoise.1.0.0.dylib
install_name_tool -id @loader_path/libOpenImageDenoise.1.0.0.dylib ./libOpenImageDenoise.1.0.0.dylib
install_name_tool -change @rpath/libtbb.dylib @loader_path/libtbb.dylib ./libOpenImageDenoise.1.0.0.dylib
install_name_tool -change @rpath/libtbbmalloc.dylib @loader_path/libtbbmalloc.dylib ./libOpenImageDenoise.1.0.0.dylib
#pyluxcore.so
install_name_tool -change @rpath/libomp.dylib @loader_path/libomp.dylib pyluxcore.so
install_name_tool -change @rpath/libembree3.3.dylib @loader_path/libembree3.3.dylib pyluxcore.so
install_name_tool -change @rpath/libtbb.dylib @loader_path/libtbb.dylib pyluxcore.so
install_name_tool -change @rpath/libtiff.5.dylib @loader_path/libtiff.5.dylib pyluxcore.so
install_name_tool -change @rpath/libOpenImageIO.1.8.dylib @loader_path/libOpenImageIO.1.8.dylib pyluxcore.so
install_name_tool -change @rpath/libtbbmalloc.dylib @loader_path/libtbbmalloc.dylib pyluxcore.so
install_name_tool -change @rpath/libOpenImageDenoise.0.dylib @loader_path/libOpenImagedenoise.1.0.0.dylib pyluxcore.so
echo "PyLuxCore installed"
### denoise
#denoise
cp ../../macos/bin/denoise .
chmod +w ./denoise
install_name_tool -id @executable_path/denoise ./denoise
install_name_tool -change @rpath/libOpenImageDenoise.0.dylib @executable_path/libOpenImageDenoise.1.0.0.dylib denoise
install_name_tool -change @rpath/libOpenImageDenoise.1.0.0.dylib @executable_path/libOpenImageDenoise.1.0.0.dylib denoise
install_name_tool -change @rpath/libtbb.dylib @executable_path/libtbb.dylib denoise
install_name_tool -change @rpath/libtbbmalloc.dylib @executable_path/libtbbmalloc.dylib denoise
echo "Denoise installed"
cd ../..
# Set up correct names for release version and SDK
if [[ -z "$VERSION_STRING" ]] ; then
    VERSION_STRING=latest
fi
### creating opencl DMG
echo "Creating OpenCL Version DMG ..."
hdiutil create luxcorerender-$VERSION_STRING-mac64$SDK_BUILD.dmg -volname "LuxCoreRender-$VERSION_STRING" -fs HFS+ -srcfolder release_OSX/
echo "Done !"
Do
chmod +x pack_lux_osx.sh
and run it
./pack_lux_osx.sh
This should end up with a distributable .dmg.
Have fun and good luck.
portfolio http://q3de.com/
Xeon X5650@4Ghz, 2x GTX 770 Phantom - High Sierra, Windows 10, Ubuntu 18.04
Fox
Re: HOWTO - compile on OSX 2020
Post by Fox » Fri Jan 17, 2020 4:00 pm
I see you have Ubuntu 18.04, i wonder if the building works on 19.10 too?
u3dreal
Post by u3dreal » Fri Jan 17, 2020 4:04 pm
OSX macos no linux
But i should work compiled it on popOS! 19.10
Post by Dade » Fri Jan 17, 2020 4:34 pm
This should go here (https://wiki.luxcorerender.org/Compiling_LuxCore) or, for consistency with other platform, in a README.txt here (https://github.com/LuxCoreRender/MacOSCompile).
Do you have an Wiki account ?
u3dreal
Post by u3dreal » Fri Jan 17, 2020 4:39 pm
I first want to try it here then if it works for others i will put it there ... and no idea if i have a wiki account
u3dreal
Post by u3dreal » Tue Jan 21, 2020 1:05 pm
So did anyone try and succeed ?
Ahr0n
Post by Ahr0n » Wed Jan 29, 2020 10:49 pm
I got stuck on this step:
change
CODE: SELECT ALL
What exactly should I do here? A simple instruction for non-terminal guy is needed :D
u3dreal
Post by u3dreal » Thu Jan 30, 2020 10:18 am
Open cmake/PlatformSpecific.cmake in a text editor and change the 1 to 0.
SET(AZURE 0) # Set 0 when compiled locally and not on azure
and save afterwards
Ahr0n
Post by Ahr0n » Thu Jan 30, 2020 10:01 pm
Okay, thanks for last reply. The next step:
1st. Question:
- Pasting this command makes nothing in terminal. I assume there are variables that I have to change but I don't know which exactly. Please tell me what I need to change to execute this.
2nd Question:
'pwd' - password here yup? so '1234' /macos?
3rd Question:
pack_lux_osx.sh
- Should I save this file in /build directory? If not where exactly?
I assume that will be everything but now I need to examine how can I go through these steps.
u3dreal
Post by u3dreal » Fri Jan 31, 2020 7:38 am
1st. Question:
2nd Question:
3rd Question:
pack_lux_osx.sh
Just adds /usr/local/opt/bison/bin to the PATH Variable. There is no visual result in the terminal.
1. copy and paste each line one by one into the terminal and execute them. You don't have to change anything !!!
2. pwd means the folder you are in !! In this case LuxCore root.
3. place the pack_lux_osx.sh in the root / LuxCore folder.
