Compile on MacOS 10.13
u3dreal
Re: Compile on MacOS 10.13
Post by u3dreal » Sun Dec 15, 2019 8:46 pm
How about setting up Azur for nightly builds for osx .... can someone point me to startingpoint ? Do i need an Azur account ??
portfolio http://q3de.com/
MacBook Pro 2013 i7 2.3Ghz, Intel IrisPro 1.5GB, Nvidia GTX750m 2GB - High Sierra
Xeon X5650@4Ghz, 2x GTX 770 Phantom - High Sierra, Windows 10, Ubuntu 18.04
acasta69
Post by acasta69 » Sun Dec 15, 2019 10:05 pm
The Azure pipeline is controlled by this script:
https://github.com/LuxCoreRender/LuxCor ... elines.yml
The first and last part carry out common tasks, in the middle there is a section for each OS.
The one for MacOS was set up time ago by robbrown and is currently disabled:
https://github.com/LuxCoreRender/LuxCor ... s.yml#L154
Each section uses scripts dedicated to each OS, they are located in LuxCore/scripts/azurepipeline:
https://github.com/LuxCoreRender/LuxCor ... repipeline
The pipeline structure has changed a bit after the MacOS part was disabled. You could have a look at the Linux section, probably it's very similar to what you need.
If anything is unclear, please just ask! :)
Windows 10 64 bits, i7-4770 3.4 GHz, RAM 16 GB, GTX 970 4GB v382.05
u3dreal
Post by u3dreal » Sun Dec 15, 2019 10:33 pm
OK I#ll have a look ... already had ;) i still wonder how to include other repos like we need the MacOSXCompileDeps ...
acasta69
Post by acasta69 » Mon Dec 16, 2019 6:34 am
You need to recreate the directory structure to build LuxCore on the azure VM. This probably includes downloading MacOSXCompileDeps to a proper location.
I'll try to post more detailed info later this morning, I'm on my phone right now...
Post by Dade » Mon Dec 16, 2019 7:56 am
Just pack the binaries in a archive that can be uploaded and downloaded from GitHub like we do with Linux: https://github.com/LuxCoreRender/LinuxC ... v2.3alpha0 (see the linux_deps.tgz ?)
Robbrawn did the same for compiling MacOS on Azure some time ago: https://github.com/LuxCoreRender/MacOSC ... beta3eases (see the MacDistFiles.tar.gz ?)
Post by Dade » Mon Dec 16, 2019 7:58 am
BTW, u3real, do you want to become the new "official" MacOS project maintainer ? Change pretty much nothing but you will have direct access to the GitHub MacOS repositories and developer private forum.
u3dreal
Post by u3dreal » Mon Dec 16, 2019 11:35 am
I think i'm almost there .. LuxCore compiles well even without tbb on brew installed .. it was ..
There just seems to be a prop with denoise now when compiled with tbb in Macdeps.
dylibbundler complains about not finding @rpath ... well maybe i should use OIDN 1.0.0 and not 1.1.0 like i do now.
I had a look at azure and it seems to be pretty straight forward. Should work now like intended.
I'll finish it for this evening ..
And yes i'd love to be official ;) ... again :)
u3dreal
Post by u3dreal » Mon Dec 16, 2019 6:56 pm
In theory the azurepipeline "should work" now with latest commits.
I'm curious...
Oh we'll have to make a release for MacOSCompileDeps first !!!
Can i merge now in MacOSCompileDeps ?? :o and release :o
still unsure with python include ... should work with pyenv ... but i had to export CPLUS_INCLUDE_PATH .
We'll see. Is there like a log i can look at ?
Post by Dade » Mon Dec 16, 2019 8:06 pm
Yes, you should.
It is all here: https://dev.azure.com/LuxCoreRender/Lux ... der/_build
u3dreal
Post by u3dreal » Mon Dec 16, 2019 8:13 pm
OK did a release and fixed link in build.sh ... now it should work if someone merges.
Cool ... 8-)
