Re: Compile on MacOS
Posted: Thu Dec 05, 2019 9:38 am
It does but it his linked against LuxCore library and LuxCore library is linked against Intel Oidn so you may be looking in the wrong link step.
http://forums.luxcorerender.org/
otool -L luxcoreui
luxcoreui:
@rpath/libomp.dylib (compatibility version 5.0.0, current version 5.0.0)
/System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa (compatibility version 1.0.0, current version 23.0.0)
/System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL (compatibility version 1.0.0, current version 1.0.0)
/System/Library/Frameworks/IOKit.framework/Versions/A/IOKit (compatibility version 1.0.0, current version 275.0.0)
/System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation (compatibility version 150.0.0, current version 1560.12.0)
/System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo (compatibility version 1.2.0, current version 1.5.0)
@rpath/libembree3.3.dylib (compatibility version 3.0.0, current version 3.0.0)
/Users/drquader/Documents/GitHub/macos/MacOSCompileDeps/macos/lib/libOpenImageDenoise.0.dylib (compatibility version 0.0.0, current version 1.1.0)
@rpath/libtbb.dylib (compatibility version 0.0.0, current version 0.0.0)
/usr/lib/libz.1.dylib (compatibility version 1.0.0, current version 1.2.11)
/System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL (compatibility version 1.0.0, current version 1.0.0)
@rpath/libOpenImageIO.1.8.dylib (compatibility version 1.8.0, current version 1.8.11)
/usr/lib/libc++.1.dylib (compatibility version 1.0.0, current version 400.9.4)
/usr/lib/libSystem.B.dylib (compatibility version 1.0.0, current version 1252.200.5)
/System/Library/Frameworks/AppKit.framework/Versions/C/AppKit (compatibility version 45.0.0, current version 1671.10.106)
/System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics (compatibility version 64.0.0, current version 1247.4.1)
/System/Library/Frameworks/Foundation.framework/Versions/C/Foundation (compatibility version 300.0.0, current version 1560.12.0)
/usr/lib/libobjc.A.dylib (compatibility version 1.0.0, current version 228.0.0)
otool -L lib/pyluxcore.so
lib/pyluxcore.so:
May be, it is here: https://github.com/LuxCoreRender/LuxCor ... cmake#L199
There is a tag in Git for v2.2 ("luxcorerender_v2.2") if you extract the sources, you can compile the v2.2 but it may a bit a waste of time (the sources were using some older version of the libraries so it may be not a trivial task to compile the v2.2 because of dependencies: you may have to compile more stuff). It may be better to focus on v2.3 and the hopefully soon to be released beta1.
