Page 6 of 17
Re: A baking test scene
Posted: Tue Dec 03, 2019 11:07 pm
Racleborg wrote: ↑Tue Dec 03, 2019 10:54 pm
A great feature!!!
Awesome!
Be-aware that there is some stuff that may not yet work correctly, for instance, I have the feeling the baked map is shifted by half-pixel (something I have still to check), baking not diffuse materials is still an uncharted territory, etc.
Posted: Tue Dec 03, 2019 11:58 pm
by Racleborg
Thanks for the warning. I was having issues with the baked texture not appearing in the correct place, so maybe that is due to the shift.
Posted: Wed Dec 04, 2019 10:56 am
by Racleborg
I think I now have the texture 'size' working. Thanks
In Cycles, the baked texture is attached to an Emission shader which is then connected directly to the Material Output. I can't see how this is possible to do in Lux. Is the method in the attached image correct?
Thank you
Posted: Wed Dec 04, 2019 4:22 pm
Racleborg wrote: ↑Tue Dec 03, 2019 11:58 pm
The problem is quite small (see the black border on the white cube ?):
You may have a different problem caused the UV mapping. For instance, this is a default UV unwrapped cube:
This is bad because you will have color bleeding between faces. It is like normal interpolation and auto-split: you need to have space in the UV map between faces or the color will be interpolated. This is an exampled of fixed UV mapping:
See how faces, in UV space, aren't anymore adjacent so color isn't interpolated anymore ?
To recap: you faces side by side if you want a smooth surface (like with normals) or you sperate them if you want and hard edge.
Posted: Wed Dec 04, 2019 4:32 pm
Racleborg wrote: ↑Wed Dec 04, 2019 10:56 am
No, it can not be done with the current version of BlendLuxCore, it requires an explicit support. LuxCore has already what is required but BlendLuxCore must be extended.
It can be done working with .cfg files (and the very latest binaries when they are ready):
1) load the "render.cfg" in luxcoreui;
2) use the "Bake All" menu command;
3) it will generate 2 additional scene "render-bakeallobjects.cfg" and "render-bakedallobjects.cfg" (notice the "bake" and "baked" difference).
4) load "render-bakeallobjects.cfg" in luxcoreui to render all the maps;
5) once you have all maps, you can load "render-bakedallobjects.cfg" in luxcoreui to do the rendering with the created bake maps (i.e. with only one ray per sample).
You can also use in Cycles, the maps baked with LuxCore
Posted: Wed Dec 04, 2019 4:44 pm
by Racleborg
Thank you again for all the help. I was wondering about rendering the baked textures in Cycles for animation and will probably give that a go as well as using the luxcoreUi.
Posted: Wed Dec 04, 2019 10:38 pm
by Racleborg
I've now got those and have managed to bake a few objects (such as a chess table top) which worked.
So, I could now possibly bake the Guru scene if that could be of help? (or just carry on testing it on other scenes)
Also, in Blender I'm using filmic, but when rendering in Luxcorerui is it using something else?
Posted: Thu Dec 05, 2019 12:48 am
Racleborg wrote: ↑Wed Dec 04, 2019 10:38 pm
Sure, the idea, at the end, is to include that scene in
https://github.com/LuxCoreRender/LuxCoreTestScenes as bake demo.
LuxCore has it is own image pipeline while BlendLuxCore does its own post-processing inside Blender (that part can not be exported and replicated by luxcoreui).
Posted: Thu Dec 05, 2019 8:44 am
by Racleborg
Is there a correct way to set up the image pipeline in Blender so that it matches Luxcoreui?
Thank you
Posted: Thu Dec 05, 2019 9:36 am
Racleborg wrote: ↑Thu Dec 05, 2019 8:44 am
This is a question for B.Y.O.B.
