Page 3 of 17
Re: A baking test scene
Posted: Wed Nov 27, 2019 2:21 pm
Racleborg wrote: Wed Nov 27, 2019 8:21 am I may have misunderstood the request for 2.80 (not 2.81). Sorry
So just in case, I have reinstalled 2.80( from Blender archives) and converted the file.
It is here: https://1drv.ms/u/s!AhdwgLaw01tLpnPzeQz ... h?e=DOmHPg
Thanks Racleblog, it looks great. The only problem is the chair, it is violet/pink, I think you forgot to pack the texture map :?:
Posted: Wed Nov 27, 2019 4:17 pm
by Racleborg
Yes, sorry, here it is: https://1drv.ms/u/s!AhdwgLaw01tLpnTBhHR ... X?e=zcQjNK
I’m glad you like it. It’s so much easier to make a nice interior render in Lux.
edited..I thought there was an emission shader in the back of the room but it was just the emission for the baked wall material. (So if you saw what i wrote about it a minute ago, just ignore me ;) )
Posted: Thu Nov 28, 2019 4:03 pm
Racleborg wrote: Wed Nov 27, 2019 4:17 pm
Thanks, I think there are a couple more of missing image maps. They are not particularly noticeable but see the error log on the right:
Posted: Thu Nov 28, 2019 4:30 pm
I have also the feeling that some normal is pointing in wrong directions: for instance the walls normal seems to point outward instead of inward. I'm not sure because for some reason I can not edit the scene and check :?:
The current baking code bakes the side of the surface where the geometric normal point. Does Cycles baking work in a different way ?
Posted: Thu Nov 28, 2019 7:35 pm
by Racleborg
Hi Dade
I’ve noticed the error message for missing textures (the books) appear randomly; then fixes itself. I don’t know why this happens, but the textures are there. I’ll delete all the original Cycles materials and maybe that will help.
I can’t see any incorrect normal for the walls on the inside of the room. None of the original geometry for the walls, floor and skirting board had thickness. I added thickness to the floor and walls using the SOLIDIFY modifier, but not the skirting which I will now do.
I don’t know why that is. Were you able to download the scene from One-Drive?
I think it’s the same and bakes to the side that the normal is facing. Maybe the problem is due to the SOLIDIFY modifier not being applied – I will do that as well
In short: I’ll fix the normals and Apply the solidify modifiers, delete all the Cycles materials, re-pack the textures, and then upload a new version.
Does that sound ok to you?
Should be done by tomorrow lunch. 😊
Posted: Thu Nov 28, 2019 7:57 pm
by Racleborg
...update:
Just checking the original geometry for duplicated vertices. There appears to be 2 in the wall, 8 in the bookshelves and 1398 in the books. I'll delete them.
Also, I'll delete the One Drive files for the moment to save confusion.
Posted: Thu Nov 28, 2019 8:36 pm
by Racleborg
In the Cycles version there often 1 UV map for the material and a separate one for the Bake. But LUX doesn’t support multiple UVs in 2.8, so the UV for the Bake got deleted. Maybe that be what is causing the problem that you are having?
Posted: Thu Nov 28, 2019 10:54 pm
Racleborg wrote: Thu Nov 28, 2019 8:36 pm In the Cycles version there often 1 UV map for the material and a separate one for the Bake. But LUX doesn’t support multiple UVs in 2.8, so the UV for the Bake got deleted. Maybe that be what is causing the problem that you are having?
I'not sure but I why I can not edit objects ? I mean, for instance, I can not left-click on an object, press tab and check the normals, etc. Are they frozen in some why ?
Posted: Fri Nov 29, 2019 8:27 am
blender 2.8 serie is right click select by default you can change it also.
(Edit)
to see normals :
Posted: Fri Nov 29, 2019 8:49 am
by Racleborg
(See image attached). If the normals are correct it is blue, otherwise red. To switch this feature on use the overlay drop down (see arrow in image) and select Face Orientation.
I have started reworking the scene. (there are some faulty normals in the chair)
