Is there a correct way to set up the image pipeline in Blender so that it matches Luxcoreui?
This is a question for B.Y.O.B. Dade
ok
Also:
Using Blender’s default cube, which is already unwrapped, then the baked textures created in Luxcoreui need to be rotated by 180° (z axis (from top view)) then scaled by *-1 (x axis) when re -imported back to Blender in order to retain its original position.
I didn’t notice the issue on the chess table-top until pieces were added and then it was obvious that the shadows were in the wrong position.
edit.. what I meant by this "then the baked textures created in Luxcoreui need to be rotated" is apply these transforms to to original UV map.
Racleborg wrote: ↑Thu Dec 05, 2019 9:43 am
You need to use an UV mapping scale of (1, -1), see my answer in the other forum thread.
Cool, thanks. Saves loads of time!
(Image attached): I'm finding, (maybe just for this instance with a default cube) that this is working. Either way, wow! - really enjoying trying this out!
I'm getting an error in the latest (1hr ago) when Load Render in Luxcorui.
The message doesn't appear for very long so have created a page snip of what's visible (attached)
If I revert back to the earlier build the issue goes away.
Racleborg wrote: ↑Thu Dec 05, 2019 3:14 pm
I should have fixed the problem.
Would it be possible to show the object name as well as the .EXR file name in the 'render-bakeallobjects.cfg' file as when there is a lot of materials that don't look too dissimilar it can be hard to tell which is which.
Real-time rendering with that kind of quality always looks amazing.
zuljin3d wrote: ↑Fri Dec 06, 2019 4:32 amDade
Will it be possible to add a denoise(OIDN) to the baking process?
It is potentially already available by configuring the image pipeline. However in my first test, Oidn was doing a mess because it isn't trained to denoise baked maps (but the latest version has a special mode to denoise light maps, something already doable with BAKECPU and more similar to combined baked maps).
We definitively need a denoiser. BCD may be an option too. It is something I need to look into.
Racleborg wrote: ↑Fri Dec 06, 2019 11:22 am
Yes, it very annoying but the problem is not LuxCore: luxcoreui and BAKECPU are already using the object name as file name. BlendLuxCore is using a Blender object memory address as object name. In the past it was using the real object name+memory address; now it seems to use only the memory address.
@B.Y.O.B., there may be some kind of regression related to Blender v2.81 (or the use of collections ?)
