Reduce the number of OpenCL kernel compilations
Posted: Wed Oct 16, 2019 2:38 pm
It is going to be a long journey. Anyway I will list here the cases that do not trigger an OpenCL kernel re-compilation anymore:
- Using/Not Using bump/normal mapping doesn't requires OpenCL compilation anymore (removed PARAM_HAS_BUMPMAPS conditional OpenCL compilation)
- Using/Not using any type of transparency doesn't require OpenCL compilation anymore (removed PARAM_HAS_PASSTHROUGH conditional OpenCL compilation)
- Changing max. path and/or Russian Roulette parameters doesn't require OpenCL compilation anymore (removed PARAM_MAX_PATH_DEPTH, PARAM_MAX_PATH_DEPTH_DIFFUSE, PARAM_MAX_PATH_DEPTH_GLOSSY, PARAM_MAX_PATH_DEPTH_SPECULAR, PARAM_RR_DEPTH and PARAM_RR_CAPPARAM_HAS_BUMPMAPS conditional OpenCL compilation)
- Changing hybrid backward/forward path tracing settings doesn't require OpenCL compilation anymore (removed PARAM_HYBRID_BACKFORWARD and PARAM_HYBRID_BACKFORWARD_GLOSSINESSTHRESHOLD conditional OpenCL compilation)
- Changing PhotonGI settings doesn't require OpenCL compilation anymore (removed PARAM_PGIC_ENABLED, PARAM_PGIC_INDIRECT_ENABLED, PARAM_PGIC_CAUSTIC_ENABLED, etc.)
- Changing force black background flag doesn't require OpenCL compilation anymore (removed PARAM_FORCE_BLACK_BACKGROUND)
- Changing variance clamping settings doesn't require OpenCL compilation anymore (removed PARAM_SQRT_VARIANCE_CLAMP_MAX_VALUE)
- Changing LIGHT_WORLD_RADIUS_SCALE doesn't require OpenCL compilation anymore (removed PARAM_RADIUS)
- Removed HitPoint struct variable size related to PARAM_ENABLE_TEX_HITPOINTCOLOR, PARAM_ENABLE_TEX_HITPOINTGREY, PARAM_ENABLE_TEX_HITPOINTALPHA and PARAM_TRIANGLE_LIGHT_HAS_VERTEX_COLOR to avoid OpenCL re-compilation
- Enabling/disabling volumes doesn't require OpenCL compilation anymore (removed PARAM_HAS_VOLUMES and SCENE_DEFAULT_VOLUME_INDEX)
- Enabling/disabling camera clipping and/or OculusRift barrel doesn't require OpenCL compilation anymore (removed PARAM_CAMERA_ENABLE_CLIPPING_PLANE and PARAM_CAMERA_ENABLE_OCULUSRIFT_BARREL)
- Changing any pixel filter related parameter doesn't require OpenCL compilation anymore (removed all PARAM_IMAGE_FILTER_*)
- Changing camera type doesn't require OpenCL compilation anymore (removed PARAM_CAMERA_TYPE)
- Changing any image map related settings doesn't require OpenCL compilation anymore (removed all PARAM_HAS_IMAGEMAPS_*)
- Changing the number of light groups used doesn't require OpenCL compilation anymore (removed PARAM_FILM_RADIANCE_GROUP_*)
- Enabling/disabling BCD denoiser doesn't require OpenCL compilation anymore (removed PARAM_FILM_DENOISER)
- Rework of OpenCL samplers code to not require OpenCL compilation anymore when changing sampler (removed PARAM_SAMPLER_*)
- Changing AOVs used doesn't require OpenCL compilation anymore (removed PARAM_FILM_CHANNELS_*)
- Adding/Removing a new light source type doesn't require OpenCL compilation anymore (removed PARAM_HAS_*LIGHT)
