Page 6 of 6
Re: (Open)Subdiv and Displacement shapes
Posted: Tue May 26, 2020 3:30 pm
by Fox
Dade wrote: ↑Tue May 26, 2020 3:14 pm
As far as I remember, BlendLuxCore has to export disconnected faces if the vertices do not share normals, etc.
Is there option in exporter to disable it?
Posted: Tue May 26, 2020 5:40 pm
Fox wrote: ↑Tue May 26, 2020 3:30 pm
Not really, you can not have a single vertex with 2 different normals (i.e. a vertex shared between two different flat faces).
Posted: Mon Jun 22, 2020 10:40 pm
The displacement shape could have an option to consider overlapping vertices as one vertex for the displacement step.
Posted: Sat Nov 28, 2020 4:35 pm
From what I know, Cycles can adaptively tessellate each face of a mesh depending on camera distance.
Dade's example shows something similar, but it currently works per whole mesh, not per face.
So for example, with Cycles you could use one huge plane for the pebbles image you posted, and the parts of the plane that are close are tessellated more than the parts of the plane in the background. Lux currently would tessellate the whole plane uniformly.
Hey Guys. i'm a bit lost with Luxcore displacement.Want to know if our displacement method is still
per whole mesh or per face adaptive like cycles one ?
Posted: Thu Mar 25, 2021 6:03 am
by AndreasResch
When using the Subdivision node in combination with the Height Displacement node - is there a way to keep the smooth shading of the surface?
Posted: Thu Mar 25, 2021 7:05 am
by TAO
I have a different question, I can not find any documentation about displacement and parameters in the wiki!
Posted: Thu Mar 25, 2021 9:51 am
TAO wrote: ↑Thu Mar 25, 2021 7:05 am
It is in the first post of this thread
Posted: Thu Mar 25, 2021 10:22 am
by AndreasResch
AndreasResch wrote: ↑Thu Mar 25, 2021 6:03 am
Some information about this issue as well?
Posted: Thu Mar 25, 2021 10:39 am
AndreasResch wrote: ↑Thu Mar 25, 2021 10:22 am
Smooth shading is preserved
Posted: Thu Mar 25, 2021 11:12 am
by AndreasResch
Here's a comparison with and without displacement.
Here are the nodes.
