(Open)Subdiv and Displacement shapes
Re: (Open)Subdiv and Displacement shapes
Post by Dade » Thu Oct 24, 2019 3:17 pm
I haven't finished...
marcatore
Post by marcatore » Thu Oct 24, 2019 3:38 pm
I hope that your last words give us room for something that reduce subdivision using camera distance (as you've already done) but along the same mesh...so at face level and not mesh level.
I'm quite sure that it will be really appreciated.
Racleborg
Post by Racleborg » Thu Oct 24, 2019 4:30 pm
it was so slow to make people cry
:lol: :lol:
Post by Dade » Fri Oct 25, 2019 8:58 am
Added an Harlequin shape (mostly to debug meshes):
It set the mesh vertex colors to an Harlequin pattern.
Egert_Kanep
Post by Egert_Kanep » Sun Nov 03, 2019 3:20 pm
Cool idea for mesh displacement, to even out normals. Could LuxCore's displacment benefitfrom this technique?
https://youtu.be/Vx_kYEUvYCA?t=575
Post by Dade » Sun Nov 03, 2019 4:02 pm
He is using the trick to export to OpenVDB and than back to smooth the normals, this pretty much equivalent to some kind of normal filtering to reduce the amount of displacement where the normals change very fast. It could be done even better by using some kind of Ambient Occlusion value (i.e. check how near are other surfaces and scale the displacement to avoid self-intersections).
It is something I can do, not sure how to prioritize it (i.e. I'm not sure how important it is) because it should be useful only with some quite extreme displacement.
Egert_Kanep
Post by Egert_Kanep » Sun Nov 03, 2019 11:15 pm
I guess if topology is evenly spread it doesn't matter. But for things like bricks and sharp hardsurface things it might be useful. I think we can replicate this with blender modifiers to check if it's really useful or not
lacilaci
Post by lacilaci » Wed Jan 01, 2020 9:07 am
subdivision shape does this weird thing where some vertices remain sharp.. Some parts of the monkey are nicely subdivided and smoothed while some remain sharp, why is that?
hmm, it seems it depends on camera angle, so this is the keep sharp borders option I assume...
I'd like to know if it's faster to use blender's subdivision surfaces or use the shape node, also which would use less memory. Or maybe there isn't any difference?
Maybe it would be nice to have the subdivision shape being used together with simplify shape and have it as a rendertime adaptive subdivision surface instead of blender's uniform subdivisions? Is the simplify shape taking into account distance from camera?
Post by Dade » Wed Jan 01, 2020 10:38 am
I would say, use LuxCore subdivision if you are going to use displacement (and may be simplify) otherwise use Blender. There isn't really a reason to leave subdivision to LuxCore if you aren't going to use some other feature.
Post by Sharlybg » Tue Jan 21, 2020 1:34 pm
Please guys what is the correct node tree and file format for Vector displacement ?
