(Open)Subdiv and Displacement shapes
Shapes
LuxCore uses shapes to build a pipeline of mesh geometry transformations (the concept is similar to the image pipelines). The output of a shape is always a triangle mesh. Multiple shapes can be concatenated to build custom transformations. For instance, some of currently available shapes:
- mesh => load a .ply file
- pointiness => add curvature information to the alpha value of each mesh vertex
- strands => load a .hair file and tassellate the strands
- etc.
New "subdiv" Shapes
I integrated Pixar's OpenSubdiv and it is now available as a shape (i.e. a geometry transformation):
scene.shapes.sphereply.type = mesh
scene.shapes.sphereply.ply = sphere.ply
scene.shapes.spheresubdiv.type = subdiv
scene.shapes.spheresubdiv.source = sphereply
scene.shapes.spheresubdiv.maxlevel = 5
"maxlevel" defines the max. level of surface subdivisions. Each level increases the amount of triangles by 4. At the moment only uniform subdivision is used.
This shape can be used before other shapes to improve their work: for instance before pointiness or displacement. It can also be used to fix some shadow terminator problem, for instance, without:
and with:
".maxedgescreensize" can be used to stop the subdivision before having reached ".maxlevel". It is expressed in size on the film image plane (i.e. a value between 0.0 and 1.0). It is trivial to translate in pixels by multiplying per "max(film width, film height). This is an example:
scene.shapes.obj_redply.type = mesh
scene.shapes.obj_redply.ply = scenes/bump/mat_red.ply
scene.shapes.obj_red.type = subdiv
scene.shapes.obj_red.source = obj_redply
scene.shapes.obj_red.maxlevel = 5
scene.shapes.obj_red.maxedgescreensize = 0.1
New "displacement" Shapes
I added the support for "displacement" Shapes. It applies a texture displacement to mesh vertices:
## From: https://3dtextures.me/2019/09/30/fabric-padded-004/
scene.textures.fabric_disp.type = imagemap
scene.textures.fabric_disp.gamma = 1.0
scene.textures.fabric_disp.mapping.type = uvmapping2d
scene.textures.fabric_disp.mapping.uvscale = 2.0 1.0
scene.shapes.sphere.type = displacement
scene.shapes.sphere.source = spheresubdiv
scene.shapes.sphere.map = fabric_disp
scene.shapes.sphere.scale = 0.15
scene.shapes.sphere.offset = 0.0
scene.shapes.sphere.normalsmooth = 1
The parameters are:
- "map" => the name of the displacement texture;
- "scale" => scales the displacement texture values;
- "offset" => added to the displacement texture values;
- "normalsmooth" => if to smooth the vertex normals after having applied the displacement.
Usually, you want to use a "subdiv" shape before a "displacement" shape to increase the mesh resolution.
And some test result:
From https://3dtextures.me/2019/09/30/fabric-padded-004:
Note: In LuxCore, displacement is a geometry transformation while (I think) it is a material attribute in Cycles. However LuxCore use one single material with each mesh so it is really only a formal difference.
New "displacement" Shapes: Vector Displacement
The new shape supports also vector displacement: the vertices can be displaced in an arbitrary XYZ direction instead of along normal as in usual displacement maps. This is the syntax for enabling vector displacement:
scene.shapes.sphere.map = vect_disp
scene.shapes.sphere.map.type = vector
# Mudbox channels order:
scene.shapes.sphere.map.channels = 0 2 1
# Blender channels order:
#scene.shapes.sphere.map.channels = 2 0 1
scene.shapes.sphere.scale = 2.0
The "map.type" property is used to enable vector displacement with "vector" (the default is "height"). Note the "map.channels" property used to remap the RGB channels of the texture. This is required because, unfortunately, there isn't a standard and the channel order differs between ZBrush, Mudbox, etc.
This is a rendering of pretty much the only test scene for Blender I have found (at https://www.youtube.com/watch?v=iNAdi1nzOvE):
The result can be quite sick ! Look at this test scene from Arnold/MudBox (https://docs.arnoldrenderer.com/display ... splacement):
Egert_Kanep
Re: (Open)Subdiv and Displacement shapes
Post by Egert_Kanep »
Yes... looks neat. But can we use procedural textures also for displacement?
Oh man, this feature adds a next level to rendering
:D
Egert_Kanep wrote: Sun Oct 13, 2019 12:55 pm But can we use procedural textures also for displacement?
Yes.
Dade wrote: Sun Oct 13, 2019 12:42 pm Note: In LuxCore, displacement is a geometry transformation while (I think) it is a material attribute in Cycles. However LuxCore use one single material with each mesh so it is really only a formal difference.
I think in BlendLuxCore I'll expose it as a socket on the material output node, this should be the most intuitive solution for the users.
Egert_Kanep
Yikes, I'm too excited now. This is one of my most wanted features.
So I see maxlevel for opensubdiv but is this the only control?
How/when do you reach maxlevel?
Is this screenspace adaptive as in cycles (min edgelength by #pixels and maxlevel to clamp?)
Edit: ok sorry I just noticed the part about only uniform subdivs supported yet :)
Impressing !
Is this have anything to do with vector displacement ?
lacilaci wrote: Sun Oct 13, 2019 1:25 pm So I see maxlevel for opensubdiv but is this the only control?
This is the options available with OpenSubdiv: http://graphics.pixar.com/opensubdiv/do ... nd-options
None of them looks required to me at the moment (i.e. the defaults should be ok).
lacilaci wrote: Sun Oct 13, 2019 1:25 pm How/when do you reach maxlevel?
It is stuff I want to explore but the subdivision is done before applying the displacement so adaptive subdivision is not particularly useful (you need the uniform vertices to evaluate there the displacement).
In a scene like this:
You need first a fine uniform subdivision or the checks would be "jagged" and only after the displacement, you could apply a simplification on (nearly) flat surfaces.
The optimal solution is to adaptively tassellate the mesh+displacement surface but it is not a simply task at all.
Sharlybg wrote: Sun Oct 13, 2019 3:01 pm Is this have anything to do with vector displacement ?
I can easily add Vector displacement but I was wondering if people have the tools to create the maps :?:
They are quite hard to encode.
Egert_Kanep
I think it is not used that often. It could be a nice to have feature, but haven't heard many people using/talking about it
Edit. Also about the adaptivness, the only case I would find it useful are huge assets like terrains. For smaller objects, products, I don't see any need for adaptivness, could produce bad edges etc.
Egert_Kanep wrote: Sun Oct 13, 2019 3:15 pm I think it is not used that often. It could be a nice to have feature, but haven't heard many people using/talking about it
I was looking around and it seems ZBrush supports vector displacement so people importing objects from there may find it useful.
