Page 7 of 8
Re: Shadow Terminator problem
Posted: Mon Aug 12, 2019 6:03 pm
by Racleborg
by Dade » Sat Aug 10, 2019 3:32 pm
Racleborg wrote: ↑
Fri Aug 09, 2019 6:21 pm
I am not sure if this is relevant to the currently discussed Bump issue, but I don't appear to be getting any Bump effect be with the Checkerboard Texture like it does with other textures such as Distorted Noise?
This should be normal: the bump is proportional to the difference of 2 adjacent pixels, if the pixels have the same color (like inside a check), there is no difference and the normal is unmodified. So it is modified only on the sharp edge between 2 checks.
Thank you for the explanation
Posted: Mon Aug 19, 2019 8:42 am
demonstration of the problem on a simple plane and weak bump
bump
no bump
file
bump.blend
(532.22 KiB) Downloaded 180 times
Posted: Tue Aug 20, 2019 9:02 am
provisory wrote: Sun Aug 11, 2019 9:27 am After some comparisons I think again, that something is not perfect with LuxCore bump mapping.
Left side is highly subdivided and has displacement modifier with the bump texture.
Right side is low poly and has bump mapping with the same bump texture.
Cycles:
LuxCore after shadow terminator taming:
LuxCore before it:
I should have fixed the problem, this is a rendering before the fix:
and this after the fix:
Extreme bump scale values are now handled far better, this was before:
Posted: Tue Aug 20, 2019 9:07 am
Dade wrote: Tue Aug 20, 2019 9:02 am
Cycles:
LuxCore before it:
This looks fantastic, how about long flat planes with bump, won't they look like they collect dust?
will give this a go as soon as it's "cooked"
Posted: Tue Aug 20, 2019 9:12 am
lacilaci wrote: Tue Aug 20, 2019 9:07 am This looks fantastic, how about long flat planes with bump, won't they look like they collect dust?
Your test scene seems to work fine with the new version:
Posted: Tue Aug 20, 2019 9:21 am
Dade wrote: Tue Aug 20, 2019 9:12 am
Amazing, thanks!
Posted: Tue Aug 20, 2019 9:22 am
by provisory
Dade wrote: Tue Aug 20, 2019 9:02 am I should have fixed the problem...
Looks good, thank you!
(I'm away from my computer for a few days. I'll test it when I'm back.)
Posted: Tue Aug 20, 2019 1:07 pm
by tokiop
Nice result and collaboration, thanks both for your investment !
Posted: Wed Aug 21, 2019 5:07 am
Just to confirm, both shadow terminator fix and bump mapping is now working excelently and in 2.81 daily build! Perfect!
Posted: Thu Aug 22, 2019 12:50 pm
by provisory
I made some tests, and I also think it works nicely.
...except the problem with the translucent materials:
http://forums.luxcorerender.org/viewtop ... f=4&t=1325
