Shadow Terminator problem
Posted: Wed Aug 07, 2019 9:20 am
Introduction
This was the starting point in a quite extreme case:
Fixing a couple of problems
As first step I have fixed 2 problems:
1) the self-shadow problem in 2 triangles with a glancing angle with the light source (i.e. see the noise due to some self-intersection of shadow rays);
2) the horrible bounce back of light intensity on the edge.
and the result is:
Note: the black triangles on the edge are unavoidable, their geometric normal points away from the light source so there is no way to fix them aside increasing tessellation and/or using softer shadows (due to a larger light source, etc.).
"Taming the Shadow Terminator" ... when using bump/normal mapping
This is another test:
Now look what happen if I add bump mapping:
Lights magically appears from no where and start to illuminate also over the shadow termination. This is what
by Matt Jen-Yuan Chiang, Yining Karl Li and Brent Burley
https://www.yiningkarlli.com/projects/s ... nator.html
can fix. This is the same rendering using the shadow terminator avoidance factor described in the paper:
Better, now the renderings with and without bump mapping match each other.
P.S. this code is not part of beta3 but only available in daily builds.
and the result is:
