Page 6 of 6
Re: Transitioning from VRay to LuxCoreRender
Posted: Sat Jul 13, 2019 1:26 am
by happyboy
B.Y.O.B. wrote: ↑Fri Jul 12, 2019 7:18 am
As far as LuxCore is concerned, every length is in meters.
Thanks!
Posted: Thu Jul 18, 2019 5:11 am
by happyboy
Another question: can we store OBJECT_ID AOV in an exr? I'm getting this error:
RuntimeError: Object ID image can be saved only in non HDR formats: 4
But in wiki (
https://wiki.luxcorerender.org/LuxCore_ ... ka_AOVs.29) OBJECT_ID is marked as "HDR".
And with VRay, it is stored in a channel of uint type instead of float type and my program can successfully read from it (and values are correct).
Is this intended, or a bug? If it's not a bug, how is it stored? I'm asking because I tried to store luxcore's OBJECT_ID AOV in LDR (a png file), but the file looks different than VRay's png.
Posted: Thu Jul 18, 2019 5:20 am
by happyboy
Also, if I defined an "ALBEDO" output, but don't have an "AVG_SHADING_NORMAL" output defined, ALBEDO won't be saved. If I defined both, both will be saved. It looks like a bug? (I'm not using OIDN in this case)
Posted: Thu Jul 18, 2019 8:12 am
happyboy wrote: ↑Thu Jul 18, 2019 5:11 am
But in wiki (
OBJECT_ID, MATERIAL_ID and SAMPLECOUNT AOVs are saved in RGB 8 bits (so only 24 bits are stored):
https://github.com/LuxCoreRender/LuxCor ... t.cpp#L483
Posted: Thu Jul 18, 2019 10:15 am
by happyboy
Thanks! The results (luxcore vs VRay) matched now.
Posted: Mon Jul 22, 2019 9:28 am
happyboy wrote: ↑Thu Jul 18, 2019 5:20 am
It was a bug and I should have fixed this problem.
Posted: Tue Jul 23, 2019 2:03 am
by happyboy
Dade wrote: ↑Mon Jul 22, 2019 9:28 am
Thanks! It works now.
