Page 10 of 10
Re: Disney shader problem
Posted: Tue Jun 11, 2019 9:00 pm
by epilectrolytics
I changed the materials in the classroom scene to Disney shaders and started rendering the animation (with PGI).
First I was positively surprised to see a substantial speed-up from 190s to 150s render time for 400 samples per frame.
But when I took a peek at the animation after the first 200 frames there was a slight flickering on the wall that was not present in the previous render with glossy and matte materials.
It turns out that the advanced GGX reflectance model throws more noise around the scene.
The light distribution is also very different, two examples without OIDN:
^ Disney
v glossy&matte (only floor, walls & desks; same cache)
I'm rerendering now with 500 samples/frame which is the same duration as with the old materials and will report tomorrow how that turns out.
Re: Disney BRDF material
Posted: Wed Jun 12, 2019 10:33 am
by epilectrolytics
After comparing animations of 500 samples per frame with Disney materials vs 400 samples glossy/matte (same render time)
I have to say there is no free lunch :|
The Disney version shows slight flickering in the corners where the walls meet the ceiling.
Probably needs 600 to 700 samples to get clean, meaning a three days instead of two days render :(
It could be caused by GGX model being more noisy, PGI brute force corner blending, OIDN or any combination of those :?
I just spend two hours to set up a demonstration video showing the effect (0.5GB ProRes 422HQ), then converted it to HEVC for upload and found that the h.265 conversion is somehow smoothing out things and the flicker is nearly gone :o
Well, yeah.
Theoretically the GGX thingy should be more expensive to render and produce more noise from those fancy reflections at grazing angles, especially with diffuse surfaces that now have a "specular" component (disabling this for walls and ceiling shortens render time by 5s and slightly darkens parts of the room) and that's what I have seen in Cycles and now LuxCore as well.
In the end it's a matter of taste.
Posted: Sat Jun 15, 2019 1:29 pm
epilectrolytics, thank you for testing the new shader in-depth.
Could you open bug reports in https://github.com/LuxCoreRender/LuxCore/issues/new with the following:
- short description of the problem
- scene showing the problem (.blend or, even better, result from LuxCore scene export in text format)
- render output images showing the problem
- a description of the steps to make to replicate the problem
When problems are only reported in posts in a 10 page long thread, it is very hard to find them again.
Posted: Sat Jun 15, 2019 2:08 pm
Do you have direct cache enable ? Or single map ?
Posted: Sat Jun 15, 2019 3:15 pm
by epilectrolytics
Sorry for being unclear in my reporting but this was not a bug report, instead all is well with the new shader and it works as (at first) expected ;)
I was just confused about the faster render time per sample and had to learn through experimenting that at the same time it converges slower so in the end there is a certain noise penalty due to the more complex reflection model, just as in Cycles or other apps.
So by all means everyone go ahead and use it because it works :!:
Single map.
Posted: Sat Jun 15, 2019 3:33 pm
Thanks for clarifying :)
Posted: Tue Jun 18, 2019 4:00 pm
by Taka
Hi there,
I noticed something with Disney material. It seems with CPU rendering, specular gets a color tint. OpenCL gives expected results.
First image is CPU, second one is OpenCL.
