lxs file halttime[SOLVED]
nigec
Post by nigec »
halttime doesn't seem to work in lxs files using the luxcoreconsole
filename also seems to be ignored but may its because halttime is being overlooked
"integer halttime" [1]
"string filename" ["_Material1"]
I got around the problem by doing:
"C:\luxcorerender/luxcoreconsole.exe" -d "C:/Users/nige/AppData/Roaming/LuxRender/" " _Material1.lxs" -D "batch.halttime" "2"
ut that doesn't solve the infile problem
pre.zip
(14.65 KiB) Downloaded 143 times
Re: lxs file halttime
LXS parser now supports halttime and haltspp film halt conditions.
nigec
Post by nigec »
thank you
