MaxToLux v0.5.4467-beta.3
I am very proud to announce the Very first
MaxToLux beta release (3dsmax internally renderer for LuxCoreRendere).
Huge improvements, compatibility, and bug fixes.
final render with a little color correction in photoshop.
Base on an old scene that I created with Vray and now completely moved it to MaxToLux.
Sample scene Base on Danish Mood Scene
Sample scene Available on GitHub
https://github.com/LuxCoreRender/MaxToL ... mpleScenes
Plugin Download link available for 3dsmax 2019-2020 https://github.com/LuxCoreRender/MaxToLux/releases
New Features
Added the support for 3dsmax 2018-2019-2020(
3dsmax 2021 And latest Arnold renderer Problem with openimageIO.dll still persist - plugin itself is ready - Do not install the plugin on 3dsmax 2021 or any other version of 3dsmax if you upgrade to the latest Arnold renderer version recently.)
Added the support for sub materials
Added the support for sub textures
support for regional local language (beta)
Add support for render
device selection
Add support for IBL (image-based lighting)
Add world volume support
Add support for Smooth segment group
Add support for multilayer material support
Add support for viewport material support (beta)
Add brand New Lux Lights
Add all image pipelines
Improvements
Faster material preview
Better material preview
Better Gamma support (Still gamma need to be set off in 3dsmax)
Better support for VFB
Better support for Clone VFB
Fixed Bugs
Fixed issue with big scenes
Fix memory leak in render time
Fixed crash if Change Material type
Fixed crash if the texture has a long path or contains space - Replaced with the asset manager for better file handling
Fixed crash if any object, texture, or material name contains a special character or space
Fix for Any object without material will be moved to the center point.
Fixed crash where no image pipeline selected
Fix glass does not render correctly
Fixed Sobol sampler does not work properly
Fix denoiser not work on the final render
Fix texture issue that causes first texture always removed from scene and cause crash on the final render
Installer Improvements
Correct name in add remove the program
Better installation handler
detect 3dsmax location
Add registry keys to handle installation and uninstallation
Knowing issues
Bump and Normal bump not working correctly.
Volumetric map Missing
Wrong category for material
Lux Cameras Missing
post-render effects like Bloom does not support yet (interface only)
uninstall plugin can cause 3dsmax crash
wrong alpha channel in VFB
Complete Release Notes is available on GitHub
https://wiki.luxcorerender.org/MaxToLux ... ease_Notes
