Page 19 of 67
Re: MaxToLux - 3ds Max Integration for LuxCore
Posted: Sun May 17, 2020 11:21 am
by TAO
Dade wrote: ↑Sun May 17, 2020 11:03 am
a1-kh wrote: ↑Sun May 17, 2020 10:42 am
Wrong number of values in property: scene.textures.Map_1.file
Is there a space in the filename? It should be enclosed in " " in that case.
I already remove all unwanted characters like space, slash, $, or anything like that and replace all with an underline. I don't think that's the case with a long path.
Also already fixed the issue with "," separator. That was really tricky.
Posted: Sun May 17, 2020 11:40 am
by a1-kh
Is there a space in file name ? It should be enclosed in " " in that case.
Hi there , no the names are all without spaces
Posted: Sun May 17, 2020 11:45 am
by a1-kh
TAO wrote: ↑Sun May 17, 2020 11:09 am
It's a known issue with a too-long image path for textures. When I parse a too long file address in LuxCore it can not find the image file.
I'm trying to fix it.
For now, you can just move your project in a smaller path, for example, d:\temp or such.
Sorry for the inconvenience.
It's a brand new plugin and there are so many things do work on, I'm trying my best.
Let me if this fixes the issue.
Thanks for the tip, yeah it worked after i shortened the path. thanks . i am testing the scene all-settings now .
Posted: Sun May 17, 2020 11:50 am
by a1-kh
Does the "TILEPATHOCL" setting run on gpu ? cause i see the cpu usage at full with many rendering tiles ?
Posted: Sun May 17, 2020 11:51 am
by TAO
Thank you for your replay.
Honestly, I don't know whats the issue with the long-path but it's not about 3dsmax and it will happen with luxCore itself.
I'm still investigating the issue.
Is there any bug tracker that we can use to organized bugs and features?
Posted: Sun May 17, 2020 11:53 am
by TAO
a1-kh wrote: ↑Sun May 17, 2020 11:50 am
Yes, it works on GPU.
Posted: Sun May 17, 2020 12:02 pm
TAO wrote: ↑Sun May 17, 2020 11:51 am
Honestly, I don't know whats the issue with the long-path but it's not about 3dsmac and it will happen with luxCore itself.
The MaxToLux github repo has an issue tracker.
Posted: Sun May 17, 2020 12:03 pm
by a1-kh
TAO wrote: ↑Sun May 17, 2020 11:53 am
oh , then i guess "TILEPATHSAMPLER" option on gpu is very slow, or doesn't use the gpu at all.
TILEPATHCPU : 1 minute = 60 samples
TILEPATHOCL : 1 minute = 70 samples ( very small gpu usage based on NVIDIA Inspector ) ( 1 GPU )
TILEPATHOCL : 1 minute = 70 samples ( very small gpu usage based on NVIDIA Inspector ) ( 2 GPU )
any thoughts ?
PS : CPU usage in 3 tests is always 100%
Posted: Sun May 17, 2020 12:04 pm
by TAO
B.Y.O.B. wrote: ↑Sun May 17, 2020 12:02 pm
Thank you.
Posted: Sun May 17, 2020 12:07 pm
by TAO
a1-kh wrote: ↑Sun May 17, 2020 12:03 pm
any thoughts ?
Can you send me some sort of GPU profiler or anything that shows GPU usage?
