Page 11 of 22
Re: MaxLuxCore - 3ds Max Integration for LuxCore
Posted: Thu Nov 07, 2019 4:26 pm
TAO wrote:
Thu Nov 07, 2019 1:21 pm
Can you show me any reference to how you do the image pipeline after rendering?
You can call Film::ExecuteImagePipeline(imagePipelineIndex) in order to run one of the pipelines you have defined and than you can collect the result by calling Film::GetOutput(OUTPUT_RGB_IMAGEPIPELINE,bufferPtr).
Posted: Thu Nov 07, 2019 8:42 pm
by TAO
Here is render.cfg
renderengine.type = "PATHCPU"
opencl.platform.index = "-1"
opencl.cpu.use = "1"
opencl.gpu.use = "1"
opencl.cpu.workgroup.size = "0"
opencl.gpu.workgroup.size = "0"
opencl.devices.select = "11"
batch.halttime = "0"
film.opencl.enable = "1"
film.opencl.platform = "-1"
film.opencl.device = "-1"
film.imagepipeline.0.0.type = "TONEMAP_AUTOLINEAR"
film.imagepipeline.0.1.type = "TONEMAP_LUXLINEAR"
film.imagepipeline.0.1.sensitivity = "100.0"
film.imagepipeline.0.1.exposure = "2.4"
film.imagepipeline.0.1.fstop = "2.8"
film.imagepipeline.0.2.type = "GAMMA_CORRECTION"
film.imagepipeline.0.2.value = "2.2"
film.imagepipeline.0.2.table.size = "4096"
film.imagepipeline.1.0.type = "INTEL_OIDN"
film.imagepipeline.1.1.type = "TONEMAP_AUTOLINEAR"
film.imagepipeline.1.2.type = "TONEMAP_LUXLINEAR"
film.imagepipeline.1.2.sensitivity = "100.0"
film.imagepipeline.1.2.exposure = "2.4"
film.imagepipeline.1.2.fstop = "2.8"
film.imagepipeline.1.3.type = "GAMMA_CORRECTION"
film.imagepipeline.1.3.value = "2.2"
film.imagepipeline.1.3.table.size = "4096"
film.height = "768"
film.width = "1024"
film.filter.type = "GAUSSIAN"
film.filter.xwidth = "1.000000"
film.filter.ywidth = "1.000000"
film.filter.gaussian.alpha = "0.100000"
lightstrategy.type = "UNIFORM"
sampler.type = "SOBOL"
scene.file = "scene.scn"
When i execute pipeline for index 0 its work
session->GetFilm().ExecuteImagePipeline(0);
session->GetFilm().GetOutput<float>(Film::OUTPUT_RGB_IMAGEPIPELINE, pixels);
But when i use index 1 plugin crash and give me error code for violation access on 0.fffffffffffff
I may miss something again.
Posted: Thu Nov 07, 2019 10:44 pm
It is "film.imagepipelines.0.0.type", you are missing an "s". The missing "s" is leading to the second pipeline overwriting the first one. So you ask for a pipeline that doesn't exist and boom.
Posted: Fri Nov 08, 2019 2:00 pm
by a1-kh
Sorry to be late, these are some snapshots of the environment variables that i found
i don't know if these are the correct ones or the others .
Posted: Sun Nov 10, 2019 1:11 pm
by TAO
Thank you so much a1-kh.
I'll going to send you new installer and with new features soo you can test and see if installer work correctlly.
Posted: Sun Nov 10, 2019 1:15 pm
by TAO
Great, thanks.
I finished it but, I'm not satisfied with the results especially with depth.
Is there any option with OIDN denoiser so i can optimize it.
Camera Depth
Interior Danish Mood Scene
Posted: Sun Nov 10, 2019 1:49 pm
You have strange color "quantization" effect. Can you post the scene in text format (i.e. .cfg, .scn, .ply, etc.) so I can try here and check what is going on :?:
Posted: Sun Nov 10, 2019 2:20 pm
by TAO
Yes about the color, i have some questions, please check the scene first.
Also if the camera changes the distance all light power will be effected and the renderer will get different results.
f.zip
(3.38 MiB) Downloaded 26 times
Everythings are same and only change is camera distance to objects.
Posted: Sun Nov 10, 2019 9:06 pm
by TAO
I think something's wrong with
scene.materials.Material_25.id = 6,728,256
, it should'nt be like this.
Posted: Sun Nov 10, 2019 9:52 pm
You may have a problem with C locale, "." Vs. "," and other nation/language related stuff.
