MaxToLux - 3ds Max Integration for LuxCore
a1-kh
Re: MaxLuxCore - 3ds Max Integration for LuxCore
Post by a1-kh » Sat Nov 30, 2019 9:37 pm
TAO wrote:
Sat Nov 30, 2019 7:00 pm
first, check if the material editor set to LuxMaxCore in the renderer options.
if it does not work tried to update to the new version and update material previews.
if it doesn't working again let me know.
Thank you.
Thanks TAO .. i tried you suggestions , still got the problem.
I tried to unlock the Material Editor Renderer , change it to several renderers, lock it back to the LuxMark renderer, still the same problem.
I hope it is an easy bug to fix :|
Best regards
Note 2 : If you can change the installer name to LuxMaxCore so it would be easier to find in the Program Uninstaller .
Note 1 : Installer still gives the Program Files(86x) path
Post by TAO » Fri Dec 27, 2019 8:58 pm
Brand new MaxLuxCore is coming soon.
Setup project updated and MaxLuxCore name is correct in remove application list now.
Complete new code for material to prevent 3dsmax from the crash, Completely crash proof even with standards renderer.
Fixed black material thumbnail.
Instead of 20 different projects for every single material, all materials are created in just one code so i can manage them better and also export them in just one dll and not 20 different (dlls) plugins. I will combine maxluxcore and materials and objects into one dll later but for the faster result, they need to be separated yet.
Plugin compile is at least 10 times faster for materials or helper objects and 4 times faster for MaxLuxCore itself so i can test everything much faster and better. (30 sec for all materials and 2 min for maxluxcore)
So many options are added by now and most materials are ready to use.
Also many fixes in renderer itself.
I hope that this build will be a complete one.
a quick look at new materials.
I need to mention, i faced a few problems too.
for example, material needs to be rendered at least 3 seconds to be visible or they will be entirely black especially in small size 20x20 pixels or sometimes 50x50 pixels.
so i set material editor preview render to 3 but it affects the loading of materials.
Post by TAO » Tue Dec 31, 2019 8:09 pm
All new materials are finished and some of 2d and 3d textures are ready to use too, and much more so i think plugin in a good place and it can be push to the repository.
B.Y.O.B. i have a question here, Should i just push it directly or push it in my own repository in GitHub and then push clone it to luxcore repository or any other way?
Post by B.Y.O.B. » Tue Dec 31, 2019 9:06 pm
However you like. There's a repo that you can use, here: https://github.com/LuxCoreRender/MaxLuxCore
Post by TAO » Fri Jan 03, 2020 9:17 am
I started to push the code, can we just change the name of plugin and repo to something like:
MtoL
M2L
MaxtoL
MaxToLux
i think its more catchy.
After all it's just a suggestion.
Post by Dade » Fri Jan 03, 2020 11:02 am
MtoL
M2L
MaxtoL
MaxToLux
It is now "MaxToLux": https://github.com/LuxCoreRender/MaxToLux (I think MtoL may be a bit too short and may confuse people looking at the list of our repositories on GitHub).
Re: MaxToLux - 3ds Max Integration for LuxCore
Post by TAO » Fri Jan 03, 2020 12:12 pm
Nice Thank you.
a1-kh
Post by a1-kh » Wed Jan 08, 2020 9:31 am
Oh great news TAO :D :D :D , may i ask you of a small tutorial of how to compile the plugin, what tools , any special settings that you may used .
Post by TAO » Wed Jan 08, 2020 10:50 am
Hi.
i'm going to add a complete tutorial about how to compile and run MaxToLux from source code.
but first, i need to fix and add a few more projects to Github.
