Dark rough glass
Dark rough glass
This is a known issue since a moment now. And even if we manage to live with that thanks to feature like shadow color it is still anoying to deal with high roughness glass surfaces. And it is even hard when you have homgenous volume in the mix.
Cycles Render
Luxcore Render
And here is a paper on the implementation :
ms_comp_final.zip
(1017.94 KiB) Downloaded 410 times
https://blog.selfshadow.com/publication ... _final.pdf
Re: Dark rough glass
Post by lacilaci »
If disney material in luxcore had multiscatter ggx this problem should be solved, unless there is some other trickery going on.
lacilaci wrote: Thu Jan 14, 2021 7:28 am If disney material in luxcore had multiscatter ggx this problem should be solved, unless there is some other trickery going on.
To the Devs is that possible and less hard ?
I think it would be easier to fix this in the rough glass code first.
Currently the disney material in Lux can't even be used to represent glass.
