Re: MaxToLux - 3ds Max Integration for LuxCore
Post by TAO » Sat Nov 21, 2020 9:41 am
patro wrote:
Sat Nov 21, 2020 9:04 am
TAO wrote:
Sat Nov 21, 2020 1:29 am
I have been trying to build a compatible version for 3dsmax 2021 and there is a conflict between different versions of openimageIO and tbb.dll that already exist in 3dsmax 2021 and the one Luxcorerender need.
Until 3dsmax 2020 I manage to solve compatibility between openimageIO.dll and tbb.dll that works out for the best but in 3dsmax 2021 Arnold renderer needs a different version and the Luxcore always try to use Dll in the 3dsmax root directory.
How can I solve this without modifying the Luxcorerender code, because I don't want to modify the Luxcore source code every time that I need to update and build the Luxcorerender code?
Any suggestions here?
Should I ask this in another thread?
Hi, maybe Dade can tell you something about, or you can try to ask on https://forums.cgsociety.org/, there are lots of coders out there which handle with 3ds max and they really try to help.
Edited:
Did you check, if your problem is caused just by a change of the folder structure in 3ds max 2021. I needed to install a plugin, which is not updated anymore and i had to recreate the structure folder of the plugin inside 3ds max 2021 roots, to make it work.
Thank you.
Yes, I'm pretty sure, if I add the correct library in 3dsmax root it will work perfectly but Arnold will stop responding.
Latest build Download link👇👇
https://forums.luxcorerender.org/viewto ... 378#p28378
Post by Dade » Sat Nov 21, 2020 10:28 am
TBB is used by Intel Denoiser so even if may be solve the problem related to OpenImageIO versions by changing our sources, it can not be solved for TBB.
It may be possible to solve the problem with some Windows specific call: https://social.msdn.microsoft.com/Forum ... =vcgeneral
May be Acasta69 can look into the problem :?:
Post by TAO » Sat Nov 21, 2020 11:49 am
Thank you, Dade.
I manage to fix TBB.dll compatibility.
The main problem is about OpenimageIO now.
I attached the openimageIO.dll that already exist in 3dsmax 2021.
OpenImageIO.zip
(2.11 MiB) Downloaded 39 times
acasta69
Post by acasta69 » Mon Nov 23, 2020 8:47 pm
i am looking into this, with little success at the moment. I am trying to have LuxCoreUI loading OpenImageIO from different locations as described in the thread linked by Dade. A so called "side-by-side assembly" is recognized, but when I move the dll to a different location (subfolder) it is not found any more.
Hopefully I can test more in the coming days or week-end.
Post by TAO » Mon Nov 23, 2020 11:10 pm
That's the exact same issue as I have. LuxCoreRenderer always looking into the root directory or "path addresses" for Dll and will use the first Dll that exist
acasta69
Post by acasta69 » Tue Nov 24, 2020 8:09 pm
After some (a lot :shock: ) more testing I have something working now.
I came to the conclusion that, when I moved the files from the luxcoreui.exe location to a subfolder, they were not found any more because the previous location was remembered.
After some more googling I have found this:
http://csi-windows.com/blog/all/27-csi- ... ng-ignored
which seems to confirm the problem. "Touching" the executable makes everything work again after a file move.
So, to recap, now I have LuxCoreUI using the correct version of OpenImageIO.dll, which is located in a subfolder, while in the executable folder a different version of the library is present (a newer version that could never work with LuxCore, so I am sure everything's ok).
To create the OpenImageIO assembly, I created a file named LuxCoreRender.DllOpenImageIO.manifest with this content:
<assembly xmlns="urn:schemas-microsoft-com:asm.v1" manifestVersion="1.0">
    <assemblyIdentity name="LuxCoreRender.DllOpenImageIO" processorArchitecture="amd64" version="1.0.0.0" type="win32" />
    <file name = "OpenImageIO.dll"/>
</assembly>
A manifest for LuxCoreUI to declare the dependency from the previous one can be this one, named luxcoreui.exe.manifest:
<?xml version="1.0" encoding="UTF-8" standalone="yes"?>
  <dependency>
    <dependentAssembly>
      <assemblyIdentity name="LuxCoreRender.DllOpenImageIO" processorArchitecture="*" version="1.0.0.0" type="win32"></assemblyIdentity>
    </dependentAssembly>
  </dependency>
</assembly>
It can be automatically generated with Visual Studio by specifying as additional manifest dependencies:
name='LuxCoreRender.DllOpenImageIO' processorArchitecture='*' version='1.0.0.0' type='win32'"
The exe.manifest must be located next to the exe, while the DLL manifest must always be together with the DLL, and both of them can be in the same folder as the exe or in a subfolder named like the DLL assembly (in my test, LuxCoreRender.DllOpenImageIO).
I ran all this using LuxCoreUI.exe as a test case, but I think it should be possible to replicate everything for the 3dsMax plugin.
I hope I did not forget some important detail.
If anything is unclear or more tests are needed, just let me know.
Post by TAO » Tue Nov 24, 2020 9:25 pm
</assembly>
  <dependency>
    <dependentAssembly>
  </dependency>
</assembly>
Thank you for solution.
I tried it and it works perfectly with "exe" file that directly access Dll libraries, but with 3dsmax no luck what so ever.
Maybe i missed something or it's not work because of MaxToLux.dlr it's already a external library and wants to call another external library.
Not sure but i tried it in so many ways with no success so far.
acasta69
Post by acasta69 » Wed Nov 25, 2020 6:13 am
What kind of library is the MaxToLux.dlr?
Can it be a DLL, just with renamed extension?
The method should work also with DLLs, just the manifest name must be different - something like "DllName.dll.2.manifest", if I remember correctly.
Post by TAO » Wed Nov 25, 2020 9:31 am
Yes exactly, it's basically a Dll that renamed to be recognized as a renderer.
I tried this method for dll as well but i get same error.
Remember it calls by loading dll itself dynamically inside of plugin. by calling HINSTANCE and LibraryCall, etc.
3dsmax manage to load side by side dlls from 2 different locations, the problem is, that any place it reads the ddls doesn't matter because as long as one library loaded the other one will be ignored and one of the plugins will crush.
acasta69
Post by acasta69 » Thu Nov 26, 2020 3:02 pm
I see, I admit that I don't now how to tackle this, it seems a bit out of our control.
Probably we can (or should) update to a more recent version of OpenImageIO after v2.5 is out, but, from what you say, it could very well cause similar problems in less recent versions.
